Side windows won't stay up. Ever see this?
Skulptorchaz
Number of posts : 227
Post by Skulptorchaz on Thu Mar 23, 2017 12:55 pm
Do your windows ever come down on their own? Mine are. I'm pretty sure it isn't ghosts. Smile
I replaced the "fuzzies" (where your arm rests) and the track that goes over the top and down the back of the window. They were shot. It helped only a little bit but, they still come down.
Is there a spring or something in there that could be worn out or adjusted?
thanks!!
Chaz
Number of posts : 11492
Re: Side windows won't stay up. Ever see this?
Post by donivan65 on Thu Mar 23, 2017 1:44 pm
Skulptorchaz
Post by Skulptorchaz on Thu Mar 23, 2017 1:52 pm
So do you think the spring would be shot?
I would have suspected maybe someone had taken it out and didn't wind the spring enough but, they are both like that and the glass is old and the felts were shot. So I don't know why someone would have been in there if not for replacing those things.
My guess is those regulators are a "dandy" to get out. Smile
kookykrispy
Number of posts : 1452
Post by kookykrispy on Mon Mar 27, 2017 8:06 am
Yes, the spring gets worn out after 50 years. the regulator is not that tough to remove. Not sure what other models/years spring might interchange, but my search would start by taking a look at the spring from chevy truck of the same year
Number of posts : 766
Post by panelmanrd on Mon Mar 27, 2017 10:45 am
the springs usually do not wear out they just break
but the shaft that the handle goes on has a spring loaded
mechanism inside it that does wear out and will need to
be replaced, you can get kits to replace them from all the
places that sell chevy truck parts (brothers, lmc, classic parts)
just buy one for the same year truck as the van you own, it will
require removal of the rivits and reattaching the new mechanism
I'm sure you can google the process and find a video on how its done
all the 66 and older chevy regulators will work the same way 67 and newer
use a different handle but the guts are very similar. hope this helps
Post by panelmanrd on Mon Mar 27, 2017 10:46 am
look up window regulator repair kits and you will find
what you need to fix it.
    Current date/time is Tue Jan 16, 2018 7:06 am
