68bigblock
lws67
    Lowering The Front
    lws67
    lws67
    Number of posts : 193
    Lowering The Front  Empty Lowering The Front
    Post by lws67 Sun Mar 19, 2017 10:31 am
    Just completed the lowering of the front on my van, 1-1/2" by de-arching the springs, shortening the sway bar links, and removing the OEM snubbers and their brackets. Used universal Rancho leaf spring clamps, and Prothane axle snubbers for Jeep CJ5/CJ7's. Used my Harbor Freight press to de-arch each individual leaf, made plates to wrap the frame where the old brackets were cutofff, with a sawzall, for more strength, drilled and tapped the frame and bolted the new snubbers on. Had to cut down the sway bar links to keep the ends level to the road.  A little paint and voila! Bonafide 1-1/2" lower in front, sway bar angled correctly, same clearance axle to snubbers, brake lines, radiator support etc clear the leaf springs as the suspension travels, and all other geometry is good. Everything clears as the suspension travels, no bottoming out. The spring still have about a 1/2" arch at ride height. A press, sawzall and vise w/hammer to bend the steel plate and time is all that's really needed. Will be awhile before road worthy, gotta install a line lock on the front brake line etc.Lowering The Front  Img_2011
    Lowering The Front  Img_2012
    Lowering The Front  Img_2013
    Lowering The Front  Img_2014Lowering The Front  Img_2015
    68bigblock
    68bigblock
    Number of posts : 44
    Registration date : 2016-03-19
    Lowering The Front  Empty Re: Lowering The Front
    Post by 68bigblock Sun Mar 19, 2017 5:38 pm
    nice, make sure and post some pics of the line lock.
    whalemstr
    whalemstr
    Number of posts : 248
    Post by whalemstr Mon Mar 20, 2017 1:18 pm
    Looks good!
    I run 14" front wheels and 15" rears to get my rig a little lower to the ground because I hate cross winds! LOL
    I really want to rebuild my front end.
    Got as far as getting the spring shackle bushings bought and shipped to me!
    LOL
    69
    69
    Number of posts : 434
    Post by 69 Mon Mar 20, 2017 1:30 pm
    Nice job. But think about the changed pinion angle (maybe shimming the rear axle?). The diff seems to be a bit picky about that, IIRC.
    lws67
    lws67
    Post by lws67 Mon Mar 20, 2017 2:15 pm
    The pinion angle hasn't change at all,  the engine/ trans mounting hasn't changed, and the rear setup is original, just to be clear. Only the front has been lowered Cool
    lws67
    lws67
    Post by lws67 Wed Mar 29, 2017 8:16 am
    68bigblock wrote:nice, make sure and post some pics of the line lock.
    Decided to install the line lock on the rear line instead, will give more control holding the front brakes with the pedal in the box during the burnout and coming out to stage vs. just locking the fronts with the lock being either on/off. These things can be used either way. This way you just lock out the rear before pressing the brakes, only the fronts will work. Using a Biondo 2 port mounted on the cross frame in front of the axle, in between the hardline and hose to the axle. Need some brake line adapters to plumb it in.Lowering The Front  Img_2020
    Lowering The Front  Img_2021
    68bigblock
    68bigblock
    Post by 68bigblock Wed Mar 29, 2017 8:22 pm
    Good idea, I never thought about putting it on the rear line. the one i have is from Hurst but i think they all work the same.
    gary h
    gary h
    Number of posts : 474
    Post by gary h Wed Mar 29, 2017 10:49 pm
    Don't forget to adjust the Headlights ! bounce
    lws67
    lws67
    Post by lws67 Thu Mar 30, 2017 4:17 am
    Yeah, always thought they go on the front but after reading that many put them on the rears and the merits of it, not to mention the room to spare to locate the solenoid! The brake system at the front is kinda cluttered already. I just really like the idea of being able to control the fronts the whole time
    lws67
    lws67
    Post by lws67 Sun Apr 02, 2017 10:47 am
    Pic of it mounted and hooked up. Will be a while before I can try it out, time for rewire job and engine building!Lowering The Front  Img_2022
    68bigblock
    68bigblock
    Post by 68bigblock Sun Apr 02, 2017 8:54 pm
    looks good, thats the way i'll go as well, i see you plumbed it the same as it would be done on the front. so i'm guessing they are not directional just a open/close solenoid?
    lws67
    lws67
    Post by lws67 Mon Apr 03, 2017 11:36 am
    The solenoid is directional, but the wiring isn't, either lead for ground and other for 12v
    playnpossum
    playnpossum
    Number of posts : 115
    Registration date : 2014-02-17
    Post by playnpossum Fri Apr 07, 2017 1:12 pm
    looks good! hit me up some time I would like to come by and check it out. I took the possum van to greenwood 2 weeks ago to camp had a ball
      Current date/time is Fri Apr 19, 2024 5:41 am
