Lifting '68 108
boogieman
Number of posts : 69
Registration date : 2015-10-12
Lifting '68 108
Post by boogieman on Fri Mar 10, 2017 8:39 am
so i really like this van and im considering lifting my 68 and doing something similar..the local spring shop said they could rearch and add a spring for $100 a corner..or just block it up? or both...? what else do i need to be concerned about? driveshaft angle, steering issues, shocks, etc?
Number of posts : 1723
Re: Lifting '68 108
Post by m1dadio on Fri Mar 10, 2017 7:22 pm
If you can avoid blocking thats best. The blocks act as a lever that accelerates spring wrap on braking as well as acceleration or when under heavy torque loads.
rattlesnake66
Number of posts : 16
Registration date : 2015-04-19
Re: Lifting '68 108
Post by rattlesnake66 on Fri Dec 29, 2017 12:17 pm
I've been there, I wanted to add a 3 inch lift front and back.
DON'T GO BLOCKS ON THE FRONT! Sketchiest drive ever! That is considering I was using CNC'd one piece cold rolled steel.
I did and immediately regretted the decision. Add a leaf and arch the front, the benefits will be that you will be SAFE, and that the ride will feel smooth. Pair that up with some good shocks and a steering stabilizer shock and you will feel a tight ride.
As a bonus you wont have to add longer brake lines.
You may have to lengthen the drive shaft though.
67VanHelsing
Number of posts : 96
Re: Lifting '68 108
Post by 67VanHelsing on Fri Jan 05, 2018 8:55 pm
That's a sweet looking van!
caleboh
Number of posts : 14
Registration date : 2017-12-25
Re: Lifting '68 108
Post by caleboh on Mon Jan 15, 2018 10:59 pm
Any update OP? What did you use to lift your '68?
Re: Lifting '68 108
    Current date/time is Sun Jan 21, 2018 9:55 pm
