Now that I got her going down the road, and not getting hot, I'm wondering if it should be pulling THAT high of rpms going down the road?
I'm running a 292 with the stock trany and 10 bolt rear end. I understand the 10 bolts were 336 (?) geared. Rolling and counting confirms that pretty close. I dont have a lot of experience with this combo but it seems a little high in the rpms. Is it?
I'm planning on putting a 700R in it, when I can come up with one but, I had also been thinking about a 350 turbo since I have a couple and they are quite a bit less to freshen up. But if I'm pushing 2500 at 55, I think I need to go with a 700. I definitely think I have enough motor to push it.
Is this about the rpm I should be seeing? Is it high for a 292?
Thanks guys..
Chaz
Thanks guys..
Chaz
