    1965 G 10 bolt rearend
    vrod64
    vrod64
    Number of posts : 67
    Registration date : 2013-07-20
    1965 G 10 bolt rearend Empty 1965 G 10 bolt rearend
    Post by vrod64 Tue Apr 11, 2017 11:50 am
    Broken Axle. Have a 65G that I put a 327 and turbo 350 tranny in. Running slicks in back.
    This weekend the rearend finally called it quits.
    can anyone tell me which 10 bolt axles are compatable for a stock 65 rearend ?
    Thanks
    Brian
    vrod64
    vrod64
    1965 G 10 bolt rearend Empty Re: 1965 G 10 bolt rearend
    Post by vrod64 Tue Apr 11, 2017 12:01 pm
    More exact question. Summit sells Part# 700115 kit that includes 29.62" axles. Are the 65 van axles 31 1/2 long ?
    Is the width of a 65 Van reaend the same as a 65 chevelle, Camero, Nova ect ?
    richie61
    richie61
    Number of posts : 445
    Post by richie61 Tue Apr 11, 2017 12:17 pm
    Number of posts : 1412
    Post by Vantasia Wed Apr 12, 2017 7:44 am
    Donivan can give you the lowdown on axle replacement, maybe just need new higher strength axles, a gear set and new bearings into your existing housing, I think there was a thread with pics on this a few years ago....the new axles have to be modified by grinding the back of the hub or something like that....anyone recall ? easier than swapping the entire rear and axle??
    kookykrispy
    kookykrispy
    Number of posts : 1533
    Post by kookykrispy Thu Apr 13, 2017 3:52 am
    No it is not the same. The van rear is wider.
    I suggest having Moser make new axles. Send them one of yours as a pattern so they get it right.
    No1rascal
    No1rascal
    Number of posts : 306
    Registration date : 2013-02-19
    Post by No1rascal Thu Apr 13, 2017 7:22 am
    I have a set from a 67 I removed a couple of years back.
    If interested send me a PM.
      Current date/time is Fri Mar 29, 2024 2:06 am
