ALL right moving right along while I have everyone's attention and the wheels are still turning can I install a 68 2nd GEN auto steering column in a 66 1st GEN van with out any major modifying I read somewhere on a post that they attach differently at the steering box??? ........... where are you donivan 65?
2nd GEN column in 1st GEN van
Joe Van- Moderator 1st Class
- Number of posts : 4619
- Number of posts : 12218
Re: 2nd GEN column in 1st GEN van
,,,,,I'm right here,,,,,,the 2nd Gen uses a 1 piece shift lever shaft, while the 1st Gen uses a 2 piece shaft,,,,,,but bottom line is they both fit the steering box,,,,,so if you get a 2nd gen steering column,,,,,get the whole column and the lever assembly off the steering box and the shift rod going back to the trans,,,,,
2nd GEN column it 1st GEN van
THANK YOU donivan 65 I knew you would know the answer you are defiantly the question and answer king of Early's thanks for the photo also. ............JOE VAN..............back to the garage.
Don, Do you have picks of all the parts that are in the upper gear indicator area on the 2nd gen shifter. I've got one here I am trying to piece together and don't know what all I may be missing.
Thanks a bunch Don!! I have the snap ring , but didn't quite know how it was used, I have the spring thing but the end is broken off. I even have part of the indicator. LOL but am missing the PRNDL part. Do any of the truck parts available replace that piece?
Thanks again , Joe
Thanks again , Joe
Digs =take a look @ brothers truck parts -there are others -I believe that indicator piece is available?
http://www.brotherstrucks.com/products.asp?dept=659
turtle13- Number of posts : 11
Registration date : 2013-01-05
[quote="donivan65"]This is the set up from a 1970 with a factory TH350 trans,,,,,,the needle got a spring to hold it in place and there is at least 1 snap ring by the needle
I am piecing this auto column together from a pile of parts!
Anyone got a part number for this spring?
Also anyone know if a spring goes at the bottom where the rod inserts into the part goes on the steering box?
