    New Battery selection
    Zonk 1/75
    Zonk 1/75
    Number of posts : 91
    Registration date : 2016-06-24
    New Battery selection Empty New Battery selection
    Post by Zonk 1/75 Sat Jun 03, 2017 2:37 pm
    My truck is an occasional driver with most time spent parked in the garage.
    After an extended absence the battery needed a charge but it drains quickly and I have to jump it often.
    I intend to install power window units, door poppers and a sound system.
    Considering running a dual battery set-up if necessary?
    Was looking at the Optima batteries. Red or Yellow ???
    How much Cold Cranking Amps?
    Options other than Optima ???
    Thanks for any input.....
    ~Z~
    New Battery selection Empty Re: New Battery selection
    Post by vanny Sat Jun 03, 2017 5:09 pm
    Here's a link to a thread that discussed this subject...I just did a search on "battery" using the search tab at the top of the page...
    https://vintage-vans.forumotion.com/t49148-battery-suggestions-and-load-requirements-for-our-vans?highlight=battery
    Hope this helps! Very Happy
    Zonk 1/75
    Zonk 1/75
    Post by Zonk 1/75 Sun Jun 04, 2017 5:05 pm
    Saw that.......
    Found this:
    Red vs Yellow
    Any reason to limit the CCA or should I get the most available ???
    Thanks
    Post by vanny Sun Jun 04, 2017 5:53 pm
    From what you were saying about adding a lot of electronics, I would lean towards the yellow top. I can't tell you from experience because I have never had an Optima. Too cheap I guess !!!
      Current date/time is Fri Apr 19, 2024 12:09 am
