Hi Gang,
Looking for some 1st Gen numbers.
If you have your either your front or rear wheel cylinders visible, can you share what casting number & size is on it. Also If you have the original installed position & rear axle ratio that would be a valuable reference.
I am hoping the guys who converted to front disc may have the pulled parts readily available.
If you just want to send me a photo that is good - gfleduc@hotmail.com
Thank-you in advance
Gary
example:
Gary
example:
