    1st Gen Transmisson Leaking
    1966G10
    1966G10
    Number of posts : 138
    Registration date : 2009-10-14
    1st Gen Transmisson Leaking Empty 1st Gen Transmisson Leaking
    Post by 1966G10 Sun Jan 08, 2017 9:33 am
    Looking for some advice here.
    I have been battling a transmission leak on my 66 sportvan for a while now. I took the trans out and replaced both front and rear main seals thinking that was the problem. I drive it around the yard and what not, I park it and after a day or so there is a good size puddle under the trans.
    I can't even see where it is coming from to be honest. Is there any place to look for on these Powerglides?
    1966G10
    1966G10
    1st Gen Transmisson Leaking Empty Re: 1st Gen Transmisson Leaking
    Post by 1966G10 Sun Mar 26, 2017 7:48 pm
    Anyone else have issues with the 2 speed trans leaking?
    Post by Digz Sun Mar 26, 2017 8:03 pm
    I'd suggest checking the dip stick tube. Pan gasket also. Fluid level rises at shut off.
    Number of posts : 2626
    Post by savage Mon Mar 27, 2017 5:25 am
    I got PG in the 65 (Rat ina Box)with the 454 & the 68 G-20 (Ghost)with the 307 & they both leak if they set for very long. Replaced gasket , filters,& fluid on both pans (few times??)and still leak
    Mine seem to be wet on pan(Have also checked them)
    Number of posts : 801
    Post by panelmanrd Mon Mar 27, 2017 6:33 am
    shifter shaft seal, speedo drive gear are possible leak
    areas, dry it all with brake cleaner and let it sit for
    a couple of days and see what gets wet. a shift seal leaking
    will also look like a pan gasket leak. hope this helps
    kookykrispy
    kookykrispy
    Number of posts : 1533
    Post by kookykrispy Mon Mar 27, 2017 7:37 am
    After 50 years of service, the pan can become deformed, especially around the bolt holes.
      Current date/time is Fri Apr 19, 2024 7:12 am
