Vanner in Los Angeles needs help
whalemstr
Number of posts : 248
Re: Vanner in Los Angeles needs help
Post by whalemstr on Tue Dec 06, 2016 9:42 am
A chunk of that is the cam... it's not a stock one... just freekin can't remember which one I put in it!!! lol
Plug order is good...
Same stat - never touched, never moved...
Timing is what I screwed with most of yesterday -
I know it's as close as I can get it - it's running at least!!!
Still not sure of the moisture coming out of the tail pipe... gotta remember to check it after I get it warmed up awhile again...
Have it pre-warmed - valve cover off - everything ready for valve adjustment time!!!
Back in awhile...
whalemstr
Post by whalemstr on Tue Dec 06, 2016 10:45 am
after the adjustment...
https://youtu.be/RmW2rHHkn7M
a couple seemed tight and a couple seemed loose...
trying it out in a few
whalemstr
Post by whalemstr on Tue Dec 06, 2016 12:01 pm
It's running and as far as I'm concerned, it's running nice!
I just took it up a hill - at 50 - and it warms up - but with the fan on it stays in the range I feel comfortable with. Traveling along at 45 or 40 it does not heat up at all - and I only turn the fan on when coming to a stop light.
I have the idle a little low, but I can live with that for now.
I loosened the adjustment on my tranny and it shifts a bit lighter - which is again okay with me. I also noticed that if I get on it, once it gets past the initial hesitation - which I am not gonna mess with right now either, - it has enough giddeeeeuoand go for my tastes - it is a loaded camper van now and still has a little oomph!
Anyway, thanks for all the help guys.
Now I have to put the camper part all back together and plan a trip back north!
If there is anyone along 99 towards Modesto let me know!
My daughter is in Modesto - so I have to stop there otherwise I would probably try 5 going north this time...
What a relief after such a long and stressful episode in life on the road with an old van!!! LOL
I may have to go 99 all the way up north just so I can stop in Oroville and say howdy?
Number of posts : 1879
Post by Seth G on Tue Dec 06, 2016 12:38 pm
Good to hear it's running ok again, bummer about the oil flinging. Hopefully the rest of your 'vacation' is great!
whalemstr
Post by whalemstr on Wed Dec 07, 2016 2:40 pm
Been taking it out and about. Seems pretty good except maybe a bit sluggish.
Will keep worling on that.
Seth, I will just make sure that the panel that got splattered - gets an oil finish on it!!! LOL
    Current date/time is Wed May 23, 2018 11:52 am
