I'm working my way through wiring up a MegaSquirt unit to control throttle body injection on my ’65 E-pup with a 240 engine. I'll be using the distributor and Ford TFI ignition module that came on f150s with the 300 engine in the late 80s/early 90s and a Chevy TBI unit that was used on the 5.0/5.7 trucks from that period. I'm adapting a Megasquirt unit I built for another project a few years ago.
I've got most of the wiring done and I'm currently running lines for the high pressure fuel pump and fuel return.
An EFI system requires an amazing amount of wire to hook everything up, including fuses, relays, power and ground wires plus sensors and controllers. Sensors include air and water temp, wideband O2 and throttle position. Of course, I have to run wires for the two TBI injectors, plus idle air control, the new fuel pump and the TFI ignition module. Surprisingly, the only two wires I’m using from the original harness are ignition start and run that hook to the starter relay. Everything else is new.
Pics of progress so far:
I added a fuel return line bung to my tank. This is a 20 gallon Mustang tank modified for use in the Econoline.
