+11
matt_the_grouch
hywaychild
PolarBear2
wdaguy
15 posters
fuel sending unit???
wdaguy- Number of posts : 155
Registration date : 2009-02-10
I know there isnt and exact duplicate. But could you tell of one that is close so I could try to bend it to work?? I heard 64 nova? has anyone tried anything else. I am sick of dropping this tank all the time.let me know Geoff
- Number of posts : 12218
Re: fuel sending unit???
crazee- Number of posts : 331
Registration date : 2009-02-24
No replacements for a first gen tank huh????
How about the second gen tank......is it the same?
And if not, can replacement sender be had?
DanTheVanMan- Commissioner
- Number of posts : 7899
Ya just got to find the right pieces and rebuild yours...
1st Gen is 30 ohm.. 2nd Gen is 90 ohm..
Nightmoves wrote:1st Gen is 30 ohm.. 2nd Gen is 90 ohm..
Hmmmmmmmmmmm.........
Not to hijack this thread. But can the second gen sender be bought still? Or is there a swap out for a different model?
I may be into this job later in the week.
Kakster- Number of posts : 236
Check out www.quantaproducts.com. I got a 2nd gen unit there. They have a bunch that one might be able to make work in the first gen.
Kakster wrote:Check out www.quantaproducts.com. I got a 2nd gen unit there. They have a bunch that one might be able to make work in the first gen.
DEAD LINK DUDE...........
Works for me? Try again, or gogle quanta products, should work.
Scott- Number of posts : 1651
The link posted above grabbed the period at the end, so it doesnt work.
Try this one..
http://www.quantaproducts.com/home.asp
Hey Kakster, what part number did you order for you 2nd Gen?
Try this one..
I put this thing together for my 65, I'm calling it a prototype so dont laugh to hard.
It originally is for a 67 suburban, but that was way long but the right shape and impedence.
I had to shorten it and relocate the actual sender to the center because of the throw on the float arm, the 1st gen units dont have the same range of movement for the float arm( shorter resistor board).
the union was a last ditch effort to save what I had , a do-over would be a sleeve type coupling Tig welded or maybe soldered on, the float arm should be longer but the guy who did the tig stuff for me accidently snapped the arm and it ended up where it is. this unit also changes things to a 3/8 feul line.
If you do attempt something like this make sure your grounded safely so as not to damge the resistor when welding. Like I said its an experiment.
Its better than running out of gas from an empty tank,,,,,,,,,
pretty cool, someone should produce them.??$$
Scott wrote:The link posted above grabbed the period at the end, so it doesnt work.
Try this one..
THANKS.......... but NO GO as they DO NOT carry the sending unit for the 67 Chevy G10 on closer examination.
QUOTE FROM THIS WEBSITE IS AS FOLLOWS-------->
"Gas tank sending unit
Applications:
Chevrolet
G10 Van: 1970-72
G20 Van: 1970-72
G30 Van: 1971-72
P10 Van: 1971-72
P20 Van: 1970-73
P30 Van: 1970-73
GMC
G25/2500 Van: 1967
G25/2500 Van: 1971-72
G35/3500 Van: 1967
G35/3500 Van: 1971-72
P15/1500 Van: 1967
P25/2500 Van: 1967-72
P35/3500 Van: 1967-72
Number of lines:1
Original Part Number:
Included with Sending Unit: Lock ring set and strainer
Packaging: Boxed
Part Number:SUFG117A "
I got one and other than a fitting for a hose barb it matches what came out of my 67. I think the 67 GMC is the same as the 67 Chevy. A call to Quanta could settle the issue as well. Polarbear got one for his van, maybe he can shed some light on this. Thei Quanta part is SUFG 117A
PolarBear2- Number of posts : 183
Mine took just a bit of bending so it would sit all the way down and seal. Other than that it works fine.
hywaychild- Number of posts : 389
Registration date : 2008-05-27
hey claim to have ine here for a 67 to 73 i don't know if it can be made to fit a first gen ???
http://www.quantaproducts.com/products.asp?dept=333
- Post n°19
Wish they had a 1964-66.....
- Post n°20
how does this Quanta unit cost??
- Post n°21
Unit Price: $56.00
- Post n°22
thats not bad. all n all...
- Post n°23
I was tolld this place had sending units for nuvesital tanks you might get lucky and find one for your tank .
i was told most run abot 30.00
yogies
18003731937
yogies
18003731937
matt_the_grouch- Number of posts : 14
Registration date : 2010-01-27
- Post n°24
- Post n°25
This add just don't seem right,,,,It shows a picture of a unit that screws in,,,,,ours use a retainer,,,,,,and it says it fits a 67 -72 or something and is 30 ohms,,,,,I don't believe that,,,,,in 67 they went to 90 ohm units in our vans,,,,,,so nothing makes sense to me,,,,,,but you can check with them and verify if it really is what you want,,,,,
