+17
Dan Scully
Falconvan
gary h
Jaydub
busman78
lired
polosteve
rustytoolss
whalemstr
21 posters
    New from Germany '69 A100 pickup
    69
    69
    Number of posts : 433
    New from Germany '69 A100 pickup Empty New from Germany '69 A100 pickup
    Post by 69 Wed Oct 19, 2016 10:06 am
    Hi folks.
    During our last vacation in California I was able to secure a A100 pickup (Model '69) with 318, 727 LF, Power Steering and five window. Pretty decent condition. Very Happy
    Electric is done (all works), Engine runs strong (approx. 17-18 inHg vac in idle).
    Some mechanical to be done (front springs rear hanger driver side is "gone", part is already available), rear bumper got a strong hit and needs to be fixed, floor pan (of course) and new windows.
    Unfortunately, power steering is leaking like hell. It's not the hoses (dry), but the control valve and the ram cylinder.
    Now, as a first step I thought about converting to manual with a "normal" drag link and removal of the ram cylinder.
    Is that possible, e.g. does the manual drag link match the pitman arm and all?
    Further, has anyone sources for replacement parts for the control valve and the ram cylinder? The on I found in the www claims he can only do Ford control valves, as the Dodges have different measurements?
    Thanks in advance.
    Number of posts : 12218
    New from Germany '69 A100 pickup Empty Re: New from Germany '69 A100 pickup
    Post by donivan65 Wed Oct 19, 2016 3:19 pm
    You got yourself what we call a Van Up,,,,,,,,,I got a van drag link laying in the garage if you need some measurements off it,,,,,,,,,,,
    ,New from Germany '69 A100 pickup Dscn9231
    69
    69
    Post by 69 Fri Nov 18, 2016 2:03 pm
    ok, short update on progress made.
    Odometer problem solved. I exchanged it with a working one from a probably 67 D-truck donor instrument cluster. Unfortunately I cannot switch the aftermarket ammeter to the original one, because the holes for the ammeter studs in the housing have been widened to fit the aftermarket ammeter Sad
    The link between the choke and the thermostat in the intake manifold has been extended. Now the choke can actually close again. Still have to set it up correctly (or just try if it runs ok).
    Tires have been changed to 215/70 all around now but will be changed to 205/75 in April next year (exchange with my more than 7 year older Chargers tires)
    New from Germany '69 A100 pickup DSC_4511
    Smile
    Number of posts : 2086
    Post by Seth G Fri Nov 18, 2016 6:20 pm
    14 or 15" rims? I'm trying to figure out why you want a narrower tire?
    whalemstr
    whalemstr
    Number of posts : 248
    Post by whalemstr Fri Nov 18, 2016 7:17 pm
    I think I will get my own container and make it a completely self contained home - and get shipped around the world! Put it in the shipping contracts and manifests that I always have one of the top bunks!!! LOL
    69
    69
    Post by 69 Sat Nov 19, 2016 12:19 am
    Its 14 inch rims.
    The original std tires were something along 165R14 (the old 80ies tires). That`s what the local "dmv" would normaly require for permission to get the truck rolling. Basically, they decide what's "street legal". I Will have to argue with them about those tires already.
    self contained container? I would bet that something like that is already available.... Cool
    69
    69
    Post by 69 Sat Nov 19, 2016 10:47 am
    Made some pics for the insurance today and moved the truck around a little bit. It ran absolutely fine, I like that Smile
    New from Germany '69 A100 pickup DSC_4534
    New from Germany '69 A100 pickup DSC_4535
    New from Germany '69 A100 pickup DSC_4533
    New from Germany '69 A100 pickup DSC_4532
    New from Germany '69 A100 pickup DSC_4531
    And the Charger has its nice and dry winter place as well:
    New from Germany '69 A100 pickup DSC_4529
    69
    69
    Post by 69 Sat Nov 19, 2016 10:56 am
    Anyone else seeing a big black border in this forum? That results in me not seeing the full pics as uploaded. They are 800px wide, should fit, I guess.... Probably just a settings issue on my side?
    Post by donivan65 Sat Nov 19, 2016 11:31 am
    Hey Jens, we choose 640 for the size when we post pictures here,,,,,
    69
    69
    Post by 69 Wed Dec 21, 2016 12:32 pm
    Not much done in past few weeks, too cold. Thanks to Don, a proper Draglink safely arrived at my house Smile. Just a little upgrade of electrical system (main switch added in battery tray). Today I had a day off and took the A100 to a local "Fahrzeugbauer", that is, he builds trailers (all, up to 16wheeler!) and has all appropriate knowledge and (important for roadworthy tests) certificates to rebuild framerails and stuff. He'll take the A100 for approx. a week end of march (fully booked...).
    Until then I'll change the draglink, remove the doghouse and renew the transmission cooler-lines. An upgrade to pertronix is also planned.
    It was fun driving around having the shorty on a trailer bed behind the Phaeton. Although, I have to admit that although the Phaeton has the V8 engine in it, the A100 (with trailer approx 2 tonnes extra, almost doubled the total weight) really sucked the power out of it. Embarassed
    Here's some pics of the trailer-combo.
    New from Germany '69 A100 pickup DSC_4607_
    New from Germany '69 A100 pickup DSC_4608_
    rustytoolss
    rustytoolss
    Number of posts : 624
    Post by rustytoolss Wed Dec 21, 2016 2:01 pm
    Pickup looks good....What kind of car is that tow vehicle ?? Also what year is your charger ?
    69
    69
    Post by 69 Wed Dec 21, 2016 2:38 pm
    The tow car is a 2009 Volkswagen Phaeton 4.2 V8, almost fully loaded (missing "essentials": door close assist, auxiliary heater). The Phaeton is a classic already, as production has ended this year and there's no real successor as of now. I think it's THE most underestimated luxury vehicle. My Charger is a '69 383 2bbl/AT/PS (granny's 2-dr-hardtop) in bright turquoise with white vinyl top.
    New from Germany '69 A100 pickup DSC_4143__
    polosteve
    polosteve
    Number of posts : 70
    Registration date : 2012-10-28
    Post by polosteve Fri Jan 06, 2017 11:56 am
    Pretty sure I remember the CL advert for that pickup - Sweet truck!
    69
    69
    Post by 69 Fri Jan 06, 2017 12:18 pm
    The CL ad was in the Santa Cruz area first at around end April to end May this last year. Then I was crossing country from NYC to SF and the ad disappeared. Shortly after, it was back in in CL LA (but the truck still in Scotts Valley), while I was in LA. When returning to SF, I was able to secure it in mid June. Smile
    New from Germany '69 A100 pickup CL-LA
    Post by donivan65 Fri Jan 06, 2017 1:03 pm
    ,,,I would not be robbing any banks in Germany with that truck,,,,,they would probably find you anywhere you tried to hide........
    69
    69
    Post by 69 Fri Jan 06, 2017 1:52 pm
    I actually do plan to at least park it inside a bank. Doing a proper inside job is out of my possibilities... lol!
    But I need better weather. It's too cold outside to do some work on the truck, this morning we had 14°F... So, focus on some stuff to do inside the house:
    New from Germany '69 A100 pickup DSC_0003
    I was able to find some rubber mat with a 'bouclé' kind of structure, which comes pretty close.
    lired
    lired
    Number of posts : 7
    Registration date : 2016-09-23
    Post by lired Sun Jan 15, 2017 12:29 am
    Hey. Nice Pickup. I have a 67 Sportsman which is on his way onto the Austrian streets. Do you have contact to other A100 owners in Germany /Austria?
    69
    69
    Post by 69 Sun Jan 15, 2017 3:48 am
    Personally, I do know one brown window camper (A108, high roof) and one white window van (A100). There should be some more in Germany (approx. 8 or so?) and one Pickup is said to have been sold to Switzerland last year. And one in England - a fellow vintage-vanner as well Smile
    Check out the dodge-trucks-forum.de (although more sweptlines there) and (of course) mopar-forum.eu (although more cars in there)
    How about an introductory post and some pics??
    lired
    lired
    Number of posts : 7
    Post by lired Sun Jan 15, 2017 7:06 am
    Thanks a lot for the links. I thought there are more As in Germany. Here in Austria I know just one other A. It's a A108 Sportsman (Window) van. I uploaded some fotos in the "Member's Van Galleries" area.
    69
    69
    Post by 69 Sat Jan 28, 2017 1:57 pm
    Holy hell - What a mess... approx. 1/10 inch (!) of dirt+oil+?
    Meine Fresse - was für eine Jauche am Motor...
    New from Germany '69 A100 pickup DSC_0041
    New from Germany '69 A100 pickup DSC_0075
    I'm curious about leaks after cleaning - lower part/engine block still to be done.
    And yes, I'll do something about the wiring.
    69
    69
    Post by 69 Sat Feb 04, 2017 2:23 pm
    Today we changed the rear axle bearings. Pretty easy, if you have the right tools at hand. A local friend helped me at his shop. Unfortunately, no photos (always the same...). A manual hydraulic press and some long rods to get'em off and a huge puller to get'em on again.
    Meanwhile, I noticed that the cable for the autoadjuster was broke. Another order at rockauto. Fortunately, it's all the same 10" brakes as with the passenger cars...
    Post by vanny Sat Feb 04, 2017 4:41 pm
    Good Progress, just keep picking away at it! Very Happy
    69
    69
    Post by 69 Sat Feb 11, 2017 10:48 am
    Yeah, it is just freaking cold outside. 32°F today. Today I replaced all brake hardware (except the linings, still good) at the rear driver side - the one with the broken autoadjust cable. All fine now, for the other side, it (I) was too cold....
    So, meanwhile I slaughtered a D100 dash for it's ammeter, it is now in its original place, replacing the funny aftermarket ammeter, the truck had. Now it looks like a fine dash:
    New from Germany '69 A100 pickup DSC_0098
    Post by vanny Sat Feb 11, 2017 3:47 pm
    Gauges look nice and clean! Good work! Very Happy
    busman78
    busman78
    Number of posts : 483
    Post by busman78 Sun Feb 12, 2017 10:07 am
    That brown scorch mark above the the amp gauge is there for a reason, the amp meter gauge is what one could call a car burner, they get hot, real hot, having it in is cool, not hooking it up is safer, just something to consider.
      Current date/time is Thu Mar 28, 2024 11:22 am
