I made these brackets from a fellow vanner's '65 and am not sure what style they are . From reading previous posts I think they are the 4th edition that take the Nova rotors/ calipers or will the Trans Am rotor/ blazer caliper set up work? If not, what calipers/rotor set-up will work with these Brackets?Thanks for any help.
disc brake bracket identification
I'm not the expert but if they are flat brackets I believe they would be for the Nova setup. M1's are off-set at the caliper ends to allow clearance for Rotors and other things .
the flat brackets take the nova rotors, M1dadio`s are not flat,
I think the year nova is 68/73 with front disc brakes, not sure
what the first year disc brakes were available on novas, but should
all b the same 68/73
m1dadio- Chevy Guru
- Number of posts : 1778
