Heatshield for 250/6 monojet
boogieman
boogieman
Number of posts : 69
Registration date : 2015-10-12
Heatshield for 250/6 monojet Empty Heatshield for 250/6 monojet
Post by boogieman on Sat Oct 15, 2016 7:00 am
Thinking of making an aluminum heatshield to sandwich between the carb and manifold on my 250 to block some of the radiant heat from the exhaust manifold...not seeing this being done, is it a good idea or waste of time?
boogieman
boogieman
Heatshield for 250/6 monojet Empty Re: Heatshield for 250/6 monojet
Post by boogieman on Sat Oct 15, 2016 11:40 am
Kinda wondering if its gonna block heat or conduct it...
Post by jrdunn96 on Sat Oct 15, 2016 4:58 pm
I had the same idea for my Epup. I've seen it done on drag cars. I think it should work in theory. Anxious to hear from people who have tried it or understand why it won't help.
Jim
Number of posts : 1984
Post by Seth G on Sat Oct 15, 2016 6:21 pm
I have seen people do it on fordsix forums. I don't have any direct experience, but it seems like it might help. If you had a phenolic spacer between the carb and the heatsheild/manifold it would isolate the carb from the shield being directly connected to it.
boogieman
boogieman
Post by boogieman on Sat Oct 22, 2016 12:22 pm
Heatshield for 250/6 monojet 20161011
see if it helps...
Rick's 66 Chevy Van
Rick's 66 Chevy Van
Number of posts : 270
Post by Rick's 66 Chevy Van on Sat Oct 22, 2016 1:51 pm
Dude let me know id buy one from you
Post by jrdunn96 on Sat Oct 22, 2016 6:39 pm
Looks great! Hope it helps.
Number of posts : 1412
Post by Vantasia on Mon Oct 24, 2016 6:36 am
I was thinking of using an insulated carb spacer, they make them for Chevy one barrels, to reduce heat transfer but was always afraid to try and back out the old studs without breaking them since you need longer studs. Left well enough alone, but has any one tried this? Wouldn't this work better than a heat shield? or even better combined with one?
http://www.ebay.com/itm/like/151094334362?lpid=82&chn=ps&ul_noapp=true
Heatshield for 250/6 monojet Kgrhqj10
boogieman
boogieman
Post by boogieman on Mon Oct 24, 2016 12:21 pm
im still using the 1/4" or so thick cardboard gasket in between the carb and heat shield..its just seeing that exhaust manifold right there...it seems pretty dumb to me to have the exhaust and intake all wrapped up next to each other
    Current date/time is Wed May 22, 2019 9:01 am
