My 1964 A van
spooks
Number of posts : 13
Registration date : 2016-09-22
My 1964 A van
Post by spooks on Mon Sep 26, 2016 1:23 pm
Hi, my name is Chris and this is my A100, only had it a week so far, i will be asking lots of questions.
All the way from Blighty.
[img][/img]
spooks
Re: My 1964 A van
Post by spooks on Mon Sep 26, 2016 1:24 pm
Number of posts : 863
Re: My 1964 A van
Post by OutofSight on Mon Sep 26, 2016 1:47 pm
Welcome aboard! Looks very nice, enjoy!
Number of posts : 8017
Re: My 1964 A van
Post by dix on Mon Sep 26, 2016 2:34 pm
very nice a100 you have. welcome to vintage vans
ask away...
Number of posts : 533
Re: My 1964 A van
Post by Van crazy on Mon Sep 26, 2016 3:41 pm
Nice find looks like lotta work done. Where is it from.How much $ you got into if you dont mind just curious.
spooks
Re: My 1964 A van
Post by spooks on Wed Oct 19, 2016 3:26 pm
Can anyone help with this question, I am gonna need a new or re con steering box, are these steering boxes used on any other Dodge models?
Number of posts : 11629
Re: My 1964 A van
Post by donivan65 on Wed Oct 19, 2016 3:39 pm
Have you adjusted the cross shaft in it or do you have other problems?
spooks
Re: My 1964 A van
Post by spooks on Thu Oct 20, 2016 10:13 am
All i have done is tighten the nut on the box, its pretty much up to the max, I have a lot of play in the steering. thanks for your swift reply mate.
Re: My 1964 A van
Post by donivan65 on Thu Oct 20, 2016 11:19 am
Is the pitman arm on in the correct position,,,,,count the turns the steering wheel makes from full left to full right and then put steering wheel exactly 1/2 the turns back to make it in the center,,,then see if the steering wheel and tires are straight,,,,everything needs to be centered for the system to work,,,,,,also, when you rock the steering wheel with your finger, does the pitman arm move meaning you got problems in the drag link or tie rod ends? you are looking for clues to find anything that is out of specs,,,,and you mean you loosened the nut, tightened the screw, then tightened the nut , right? These are just some tests so we know what you got going there across the pond......
spooks
Re: My 1964 A van
Post by spooks on Thu Oct 20, 2016 12:55 pm
Yes I loosened the nut, tightened the screw and re tightened the nut, I will try what you said above at the weekend, as it is at the moment I have about Two inches of play when the van is on the ground,when I had it up on axle stands the other week i had no play at all if this makes sense.
I will report back over the weekend,many thanks for your help buddy.
Re: My 1964 A van
Post by donivan65 on Thu Oct 20, 2016 3:04 pm
I like to get on the same page, so we are talking about the same thing,,,,,that slop in the steering wheel is looseness somewhere,,,,,so you look whats moving and where it stops,,,,,suspects also are the ball joints on the drag link and tie rod ends,,,,,kingpin bushings,,,,wheel bearings,,,,loose lug nuts,,,,,see what you can find,,,,,,
Number of posts : 1412
Re: My 1964 A van
Post by Vantasia on Fri Oct 21, 2016 6:51 am
Agree, if there was no play up in the air and then play with the wheels on the ground and essentially restrained and then there is movement, then its probably in the linkage somewhere. Gear boxes do wear out but generally it takes 100K+ miles for that to happen....nice looking color combination on your van, always like them back in the day...
spooks
Re: My 1964 A van
Post by spooks on Sat Oct 22, 2016 12:16 pm
I had a quick look at the van today, when I turn the steering wheel to the left i get a loud creaking noise, nothing when turned to the right.
Hopefully tomorrow my son will pop over and I can get underneath the van and take a look.
I will take some photos of anything that I find suspect and upload em here.
Cheers Chris.
Re: My 1964 A van
Post by Big W on Sun Oct 23, 2016 7:12 pm
Great looking van Chris. Welcome aboard.
gary h
Number of posts : 305
Re: My 1964 A van
Post by gary h on Fri Nov 11, 2016 9:10 pm
Welcome to the forum cheers
Re: My 1964 A van
    Current date/time is Mon Jun 25, 2018 12:29 am
