West Coast Mirror Studs and lower mounting Bolts
Vanadian
Number of posts : 187
Registration date : 2010-11-17
Post by Vanadian on Tue Aug 16, 2016 10:33 pm
I'm looking for the hardware for a set of West Coast Mirror Studs and lower mounting Bolts. I'm sure i can make it work but if someone has a line on next to original Hardware I'd appreciate it.
Number of posts : 1412
Re: West Coast Mirror Studs and lower mounting Bolts
Post by Vantasia on Wed Aug 17, 2016 5:30 am
I'm thinking of adding them to my van too...I would just use stainless 1/4"-20 x 1/2" or 3/4" bolts for the studs, should fit behind the weather strip and allow the door to close, the heads aren't too thick (or grind them down). You could also use brass toilet mounting T-head bolts cut down, I think they are 5/16" size and they sell them separate and in stainless too....I may try those myself.
Number of posts : 774
Post by panelmanrd on Wed Aug 17, 2016 6:58 am
I`m parting out a 67, I think I have the bolts that you need, I will check this weekend
and let you know.
Post by Vantasia on Wed Aug 17, 2016 10:44 am
If not, make them from these, should work great and they sell stainless/chrome Acorn nuts online here:
http://www.chromenuts.com/
Vanadian
Post by Vanadian on Wed Aug 17, 2016 11:05 am
Thanks that help a bunch! Let me know if the 67 has them.
gfleduc
Number of posts : 130
Post by gfleduc on Thu Aug 18, 2016 12:30 am
I bought screws configured the same as the factory for the lower mounting on ebay (one difference they are SS). Drop me a PM if you want me to get the specs (I am not home right now).
Update:
ebay vendor lightningstainless
Pan Head Machine Screws 5/16-18 x 1/2" Stainless Steel
Post by panelmanrd on Fri Aug 19, 2016 6:47 am
I will check on those bolts tonight and let you know,
I found 2 bolts and three nut at home in the nut n bolt collection
that I have, so far I have half of what you need.
Post by panelmanrd on Fri Aug 19, 2016 5:30 pm
Just got home from taking the mirrors off the 67, I have all the mounting
Bolts and studs, just tell me where to send them
Buddyr
Registration date : 2015-10-08
Mirror studs
Post by Buddyr on Fri Aug 19, 2016 8:18 pm
Vanadian
Post by Vanadian on Sat Aug 20, 2016 9:09 am
Thanks Buddyr! Again Wink
Vanadian
Post by Vanadian on Sat Aug 20, 2016 9:21 am
Panelmanrd you are the man! PM sent!
Vanadian
Post by Vanadian on Thu Sep 01, 2016 9:26 pm
Panelmanrd, you "are" the man! Package arrived today! cheers
They are perfect!
Post by panelmanrd on Fri Sep 02, 2016 6:32 am
I chased the threads on the studs that the upper mounts use
glad that I could help out
    Current date/time is Mon Apr 23, 2018 9:37 pm
