Here's another little problem I could use some ideas with. So the top bolt for the rear shock is seized in the sleeve that goes through the frame, I tried soaking with pb blaster for days. Nothing. I used a acetylene torch on both ends , glowing red, NOTHING. I cut the floor above the frame where the bolt penetrates, torched red hot, NOTHING. I then drilled two holes into the bolt sleeve, soaked with PB blaster, NOTHING.
My next move is to cut out and weld in something to replace the bolt sleeve unless there's a better way.
