Headlight conversions?
Canada17
Number of posts : 47
Registration date : 2016-03-21
Post by Canada17 on Fri Jul 29, 2016 4:02 pm
Hi everyone,
I'm wondering what people have done for headlight conversions. it would seem to be easy enough to go with a higher output halogen, but has anyone converted to LED or HID? I know that HID would require a new reflector. Just curious.
Pics would be great.
Thanks,
Kyle
62stationbus
Number of posts : 21
Registration date : 2017-01-10
Re: Headlight conversions?
Post by 62stationbus on Fri May 12, 2017 12:13 pm
I just bought these 75w LED 7" headlights from amazon for around $90pair. I like them alot. I was able to wire in the daytime running lights and turn signals. they fit perfectly in the retaining ring and plugged right in. The light is a crisp white, super good viability, and they look modern/cool! " /> f\
62stationbus
Post by 62stationbus on Fri May 12, 2017 12:20 pm
[img][/img]
Irons
Number of posts : 14
Registration date : 2017-04-26
Post by Irons on Fri May 12, 2017 2:14 pm
Ditto...I did the same recently too.
Number of posts : 371
Post by jrdunn96 on Fri May 12, 2017 3:24 pm
62stationbus wrote:I just bought these 75w LED 7" headlights from amazon for around $90pair. I like them alot. I was able to wire in the daytime running lights and turn signals. they fit perfectly in the retaining ring and plugged right in. The light is a crisp white, super good viability, and they look modern/cool! " /> f\
Have you got a link? Or a brand & part number? I did a search of 7 inch 75 watt led headlights & got 40 something pages. I didn't know if they were about the same or some are better than others.
Thanks,
Jim
62stationbus
Post by 62stationbus on Fri May 12, 2017 6:28 pm
62stationbus
Post by 62stationbus on Fri May 12, 2017 6:43 pm
Thanks,
Jim[/quote]
Jim, I don't know if these lights are better or worse than other brands, I liked the look of these and the price even more! I can tell you that I took one of them apart and saw that they are built really well. Before I installed them, I hooked them up to a cordless drill battery to test them out. I ended up frying one due too putting net to positive and vise versa. I emailed the seller and they sent me a new pair two days later. The box says made in China but they are solid and even have an anti flicker box,, it has two small capacitors and a few resistors to maintain a constant voltage
Post by jrdunn96 on Sat May 13, 2017 3:30 pm
Sounds like a deal! Thanks!
Zonk 1/75
Number of posts : 80
Registration date : 2016-06-24
Post by Zonk 1/75 on Sat Jul 22, 2017 6:44 pm
Did those LEDs have the alignment notches like on the stock headlights? Or can you position them as you like?
Do these just plug in to the stock connectors or did you wire them?
Do these need relays?
Thanks!
    Current date/time is Sat Jun 23, 2018 8:37 pm
