Yes, I had lizard Skin SC shot throughout the rear ceiling walls, floors. I bought the Quiet Ride pre cut insulation kit for our vans. It comes pre cut with the noise dampener pieces and the glue + the insulation and aluminum tape. It made it much easier than cutting and trimming. So then I finished the floor insulation and laid down 3/4" #1 plywood over the whole floor. Cut into three pieces, front, middle and rear.Vantasia wrote:JackeFriend wrote:Worked several hours yesterday, dripping in sweat. Floor insulated, 3/4" wood cut and in place with a few set screws... too tired to finish last night at 8 PM.
Had a difficult time fitting the rear portion of plywood around the gas filler etc in the back corner. But with many attempts, it was fit to my satisfaction, which seemed to be easier to attain as the time grew later?? LOL Good enough for "government" work as they say... not building a house! I used #10 SS 1-1/2" screws. Very secure even with just the 10 set screws in place. I will do the walls next then finish the ceiling insulation. This is a lot of work!
Did you put a layer of insulation under the plywood? A layer of thin bubble foil wrap (Lowes, HD) really helps with road noise and heat/cold in addition to the wood. Cheap
http://www.homedepot.com/p/Reach-Barrier-4-ft-x-25-ft-Air-Double-Reflective-Polyethylene-Insulation-Roll-DD48025/204476656?cm_mmc=Shopping%7cTHD%7cG%7c0%7cG-BASE-PLA-D22-Insulation%7c&gclid=EAIaIQobChMI0o32u_i91QIVyFcNCh2rqQ_dEAYYBSABEgKMgPD_BwE&gclsrc=aw.ds&dclid=COnPr8P4vdUCFci4swodaDsCLw
Used #10 ss 1-1/2" screws to secure the wood down tight. I just did 10 screws last night around perimeter, as I was beat from the drilling through wood into floor and cutting of the plywood. I do not have a shop... used my jig saw, cutting over a pallet on the gravel. I do not like using the skill saw. It scares me, because I have never worked with it much. I like my thumbs etc. So slow and stead with my skill saw. Yes, I broke a few blades but I still have my fingers.
Going to rest up and have some fun this weekend... next the walls and ceiling install coming in a couple weeks.
