Side and back door rubber
Number of posts : 597
Post by samsvan on Tue May 31, 2016 1:30 pm
I bought the rubber seals for my side and back doors from Steele. They came with the pre-formed corners and now that they're in they're pushing the doors out towards the middle gap. I tried clamping them tight at the hinge side for about a week to try to "train" the rubber but no luck. Is this something that will fix itself in time or did I maybe glue them on wrong? We made sure the gaps between the doors were perfect before I took it to paint because we did away with the hinge gaskets. Here's some pic's.
Number of posts : 828
Re: Side and back door rubber
Post by jrinaman on Tue May 31, 2016 5:14 pm
just did this myself, 10 minutes ago! I have the same issue. in my case, there is play in my hinges and rubber is pushing doors inward. I have better hinges I will be installing, someday.
Post by samsvan on Wed Jun 01, 2016 3:09 pm
I'm thinking about filleting a piece out of the corners to make them a little thinner. I think I could glue the rubber back together if I took a slice out of the middle of each corner.
Post by jrinaman on Wed Jun 01, 2016 6:10 pm
you could apply pressure on the top hinges and bend them outwards. its not the hinge your bending, its the sheet metal its bolted to. 1/32" on each hinge is all you need.
    Current date/time is Fri Feb 22, 2019 2:20 pm
