Steering ?
Number of posts : 533
Steering ?
Post by Van crazy on Sat May 28, 2016 3:18 am
Should my steering wheel return to center after a turn? or is it the way it is without power steering or is somthing not right?
oldhornjunkie
Number of posts : 44
Registration date : 2016-04-02
Re: Steering ?
Post by oldhornjunkie on Sat May 28, 2016 3:35 am
Yes. Sounds like an Alignment issue or someone made the backlash in the steering gear too tight.
Number of posts : 1723
Registration date : 2008-10-07
Re: Steering ?
Post by m1dadio on Sat May 28, 2016 4:20 am
yes it should return
On a straight axle vehicle its a caster issue usually worn king pins or leaf spring sag. The caster is usually about 2 or 3 degree but I find bunping up the wedges to around 7 degree works better for straight axles. and then you have to reset the tow in. start by greasing everthing and change any worn parts.
m1D
Re: Steering ?
Post by Van crazy on Sat May 28, 2016 10:32 am
I might have spun the axle when i put it in.
Re: Steering ?
    Current date/time is Sun Jan 21, 2018 4:16 pm
