Rod clip retainer rear door Chevy 1969
marco_chevy
Number of posts : 96
Registration date : 2015-05-23
Post by marco_chevy on Mon May 23, 2016 6:09 am
Need your help. It have A rod in the back door that was locked in the door. Not able to open. I finally open whit A screw driver in the bottom of the door. I Need A retainer clip that go in this Rod. What It the name of this Rod ? The name of the retainer clip ? Thanks
Number of posts : 1732
Re: Rod clip retainer rear door Chevy 1969
Post by m1dadio on Mon May 23, 2016 7:14 am
Those clips are hard to find new. I don't know of anybody finding a reasonable replacement.
There is a part number for them (I cant remember) I search every where a couple years bak and found three NOS clips I promtly purchased.
I recomend saving every used one anybody can find. You need to be real carfull removing the clip.
I made a special tool to release the clip. Simple tool with two pins to get under the two sides of the clip stratling the door latch pin.
You might look fpr a clip in the bottom of your doors and use a magnet. I have found lots of unused and NOS parts in the bottom of doors.
M1D
Number of posts : 483
Post by samsvan on Mon May 23, 2016 3:13 pm
I've twisted a piece of wire around the notch in the pin that the rod goes on to act as the clip. Not much room to work in there but it can be done.
marco_chevy
Post by marco_chevy on Mon May 23, 2016 4:37 pm
I have put an other modl of clip , hard to clip buy i think It will be safe. Thanks
    Current date/time is Tue Apr 24, 2018 7:08 am
