RF Man
johnnyvee
    Champion radiator 6065LD
    johnnyvee
    johnnyvee
    Number of posts : 30
    Registration date : 2015-11-06
    Champion radiator 6065LD Empty Champion radiator 6065LD
    Post by johnnyvee Sat Dec 26, 2015 3:18 pm
    Hi All, Hope everyone had a safe and Merry Christmas.
    I am going to buy a Champion radiator #6065LD for my 1963 Ford Econoline pickup that has  a 3 spd tranny. Before I do, I have a few questions.
    1) will the mount holes of the radiator, line up with the holes on the frame, that is bolted to the doghouse?
    2) will there be a clearance issue between the fan and the radiator?
    3) and the main question is, the inlet and outlet on my old radiator are both 1 1/4". I see the Champion 6065LD has an inlet of 1 1/2" and an outlet of 1 3/4". That could be a problem unless there is a solution to this, other that having 1 1/4" inlet and outlet's put on them.
    Please chime in, and thanks for your help..........John
    RF Man
    RF Man
    Number of posts : 120
    Champion radiator 6065LD Empty Re: Champion radiator 6065LD
    Post by RF Man Sun Dec 27, 2015 3:05 am
    johnny---I installed one of those radiators into my 61. I did have to reem out the mounting holes ever so slightly and trim a very tiny amount off the drivers side mounting tab. I was amazed how good it fit into the vehicle. As for the inlet/outlet size, I didn't even know there was a difference. I just used standard econoline hoses and chinched them down with standard hose clamps. Maybe I just got lucky. Maybe someone else will chime in with their experience. Good lucl.
    Mike
    Number of posts : 2086
    Post by Seth G Sun Dec 27, 2015 9:06 am
    I think there are 2 models for the Econo, may be the difference?
    Post by Seth G Sun Dec 27, 2015 1:55 pm
    Well, it states on Champions website that the 6065LD has 1.25" ports in and out, so that is the one you're looking for. There is another one that has the 1.5" and 1.75" but apparently that one isn't it and I don't see it listed on there website at the moment. Iirc, it's something like 6065XX don't remember the suffix.... maybe SD?  scratch
    http://www.championradiators.com/ford-econoline-van-radiator-1960-1965
    Post by Seth G Sun Dec 27, 2015 2:19 pm
    Looks like they've changed the model # of the other one and don't have it indexed well in their lists. It's now # MC251
    http://www.championradiators.com/product/MC251
    johnnyvee
    johnnyvee
    Post by johnnyvee Sun Dec 27, 2015 2:51 pm
    Seth, the 6065Ld looks liike it will work perfect. The mounts are on the correct side of the radiator and the inlet and outlet are the right side. The 6065LD I saw on line had 1 1/2" inlet and 1 3/4 outlet. I will call them Monday to make sure.
    Thanks.........John
    Das Boot
    Das Boot
    Number of posts : 76
    Post by Das Boot Wed Dec 30, 2015 11:31 am
    John,
    I wouldn't sweat the hose sizes.  Here's a chart of Dayco's Flex Hoses. An 81081 works fine on the top. The bottom I don't know - I have the LP version.
    -Brian
    Champion radiator 6065LD Flex_h10
    johnnyvee
    johnnyvee
    Post by johnnyvee Thu Dec 31, 2015 11:45 am
    Thanks Brian. I called Champion and asked them to check the inlet and outlet. They called me back and said the info that shows, 1.5 and 1.75 is wrong. The correct info will be updated to 1.25 and 1.25. So I ordered a 6065LD. It should arrive next week. Thanks again for everyones help ........Happy New Year...........John
    QCT
    QCT
    Number of posts : 559
    Registration date : 2015-01-01
    Post by QCT Mon May 09, 2016 11:47 am
    Hey John. Any reviews on your new Champion radiator? I'm looking into getting one, they seem to be a great value.
    Post by Twinpilot001 Mon May 09, 2016 6:34 pm
    I have 3 champion rads. all 3 core ones- cool better than anything!! They are a quality product
    neondv8
    neondv8
    Number of posts : 278
    Post by neondv8 Wed May 11, 2016 7:30 pm
    Just watch out for electrolysis. I had no idea about this and I lost one to corrosion. I put the zinc thing in the drain plug and everything seems to be working out great on my second champion radiator
    Post by Twinpilot001 Wed May 11, 2016 7:44 pm
    Illadd= the radiator stop leak stuff - use only compatable stuff for alu. Radiators-or corosion gets bad!!
      Current date/time is Fri Apr 19, 2024 6:46 am
