Voltage spike and missing badly
Number of posts : 533
Post by Van crazy on Fri May 06, 2016 6:03 pm
I broke down today and Im stumped as to whats wrong. The van idles nice but as soon as i give it gas voltage spikes and runs rough....real rough...Dodge 318
Number of posts : 11535
Re: Voltage spike and missing badly
Post by donivan65 on Fri May 06, 2016 6:49 pm
see if disconnecting the vacuum advance hose changes anything,,,,
Post by Twinpilot001 on Fri May 06, 2016 7:11 pm
Have you looked @ the point set?? check inside the dizzy - carefully!! Look @ all on the advance plate!! affraid
Post by Van crazy on Sat May 07, 2016 1:05 am
I did Twinpilot I looked all over did not notice anything. I will try that Donivan. Im also going to get a fuel filter and see what that does.......
Post by Van crazy on Sat May 07, 2016 1:25 am
Donivan That was it when I disconnect the vacuum advance smoothes right out pretty much. I guess you want me to vacuum test it ... I will after I get back from work this morning thank you......
Post by donivan65 on Sat May 07, 2016 6:49 am
that can still lead back to the advance plate,,,,as soon as you hit the gas pedal, the carb sends a vacuum signal to the vacuum advance for it to move the breaker plate and points,,,,something could be loose in that area,,,,
Post by Van crazy on Sat May 07, 2016 7:01 am
pulled a vacumm it moves the advanced plate......
Post by donivan65 on Sat May 07, 2016 7:31 am
did you do it while the engine is running to see if moving that breaker plate makes the engine run bad,,,,
Post by Van crazy on Sat May 07, 2016 7:42 am
Went back out ...yes when I pull the plate running badly. I could only pull 7 on the vacumm gage when running but definatly the problem. I lubes the contact points on the plate also moves freely.
Post by Twinpilot001 on Sat May 07, 2016 7:53 am
replace the Vacumn advance,points, CONDENSER!!!!! and lube the cam!! Look @ the wire going into the dizzy from coil!!! CLOSELY!! and set points with a DWELL METER!! cheers
Post by donivan65 on Sat May 07, 2016 10:20 am
that sounds like a ground problem,,,,,the points need to be grounded,,,sometimes you need a little ground wire to ground that breaker plate to the base if you cant fix it
Post by Van crazy on Sat May 07, 2016 3:06 pm
GOT IT............... You truly are the man Donivan. I had to clean the 3 contact points on the advance plate. Thank you so much.I would have been on this for a lifetime I bet ....and I hate not drivin the Van........I have fallen in love with this van it wasnt the prettiest but it has treated me great so far.
Post by donivan65 on Sat May 07, 2016 4:34 pm
your welcome,,,,,,all the way here from from Possum Trot, Kentucky,,,,,,
    Current date/time is Sun Feb 25, 2018 7:58 am
