master clinder for a100 disc brakes
Number of posts : 8169
master clinder for a100 disc brakes Empty master clinder for a100 disc brakes
Post by dix on Tue May 03, 2016 3:52 am
Number of posts : 533
master clinder for a100 disc brakes Empty Re: master clinder for a100 disc brakes
Post by Van crazy on Fri May 13, 2016 6:22 pm
Dix is it nessesary to cut out some panel with the new master. I have been having a hard time getting one to fit stock.
Post by dix on Sat May 14, 2016 3:28 am
yes there is some cutting out needed
hemicop
hemicop
Number of posts : 87
Registration date : 2011-12-18
Post by hemicop on Fri May 27, 2016 11:09 am
Got a part number for this master cylinder?
Well, I found the part number for the MC. Anyone have , or know where I can get, the correct proportioning valve?
BTW, once the maching & all the parts have been procured, about how long does this swap take? I've seen the stud "issue" thread, but the rotors come with studs. Why wouldn't I want to use them?
Last edited by hemicop on Sat May 28, 2016 2:25 pm; edited 1 time in total (Reason for editing : add'l info.)
Post by dix on Sat Jul 16, 2016 12:17 pm
sorry never seen the post from hemi cop. do you still need help ??? sorry
busman78
busman78
Number of posts : 483
Post by busman78 on Sun Jul 17, 2016 6:23 am
I would like to see a list of part numbers since the Wagner listed by Scarebird is no longer available and some master cylinders listed in the disk brake thread are for use with power booster brakes and not for manual brake systems. Curiosity.
busman78
busman78
Post by busman78 on Sun Jul 17, 2016 6:34 am
Just to get the list going:
Doctor Diff Aluminum Master Cylinder 1-1/32" bore with 4 stud adapter for B/E Bodies with manual brakes. It is new and will set you back a C-Note.
Post by dix on Sun Jul 17, 2016 7:24 am
go to rock- auto / dodge /1973/ b-200/ brakes /master cylinder then look at the ones that say front disc rear drums for $22./$29. pick what your comfortable with. I'd use a brand name.
apedave
apedave
Number of posts : 31
Registration date : 2017-05-09
Post by apedave on Mon Mar 12, 2018 6:42 pm
I was planning on doing the disc upgrade, but don't have the budget for the full project yet. I have developed a leak at my single circuit master cylinder, so my question is this:
Can I do this upgrade is stages, ie will the master cylinder for the disc conversion work with the factory drum brakes? Or is my van going to be off the road until I save up enough pennies for the full conversion?
Thanks!
Dave
busman78
busman78
Post by busman78 on Mon Mar 12, 2018 6:55 pm
Yes, the master cylinder that I got from Doctor Diff has a 1-1/32" bore which works for drum and drum/disk. Make sure you get the adapter plate that converts the two hole MC to the old four hole mounting on the van. You will need to bend up some new brake lines to fit the MC.
apedave
apedave
Post by apedave on Mon Mar 12, 2018 7:48 pm
Awesome, thank you! That helps a lot.
Dave
    Current date/time is Sun Mar 29, 2020 5:28 am
