jmon77
    Wheel size on front question
    jmon77
    jmon77
    Number of posts : 19
    Registration date : 2013-06-30
    Wheel size on front question Empty Wheel size on front question
    Post by jmon77 Thu Apr 07, 2016 9:19 am
    I was wondering. Can anyone tell me if 15x7 wheels will fit in the front of a 1965? Thanks.
    Wheel size on front question Empty Re: Wheel size on front question
    Post by Digz Thu Apr 07, 2016 9:57 am
    If they don't have a deep dish offset they are ok. Just watch the OD of the tire. Mine are 26 inches tall but I'm sure you can be a little more than that.
    Number of posts : 512
    Post by pan58head Thu Apr 07, 2016 5:22 pm
    Yeah I have 15x8 with 235 60 15 on the front but I trimmed the fronts a little
    Number of posts : 698
    Post by Russell Fri Apr 08, 2016 8:51 am
    I have 15x7's on mine with 225/60 15's on the front of mine with 2 leafs taken out of the springs with no rubbing.
    Wheel size on front question Dog_be10
    jmon77
    jmon77
    Post by jmon77 Fri Apr 08, 2016 8:18 pm
    Awesome. Thanks guys.
    AzDon
    AzDon
    Number of posts : 741
    Post by AzDon Sat Apr 16, 2016 10:45 pm
    I'm curious because I'm considering removing front leaves.......Does the van handle and track okay? How about braking? How many leaves are left after removing two? Which two did you remove? That van looks awesome!
    Number of posts : 1046
    Post by VANagain Sat Apr 30, 2016 10:15 pm
    I plan to remove some leaves from the front of mine too. For some reason, after I took apart my leaf springs, sandblasted and painted them, the van is sitting up too high. I am going to try removing the tiny one on the bottom, and one more to see if that gets it to at least a normal height. Not sure which one though. Not the long ones, so maybe the third one. Smallest, skip one, then the next one.
    I've heard that Sportvans come with one more leaf than the panel vans. Here's a picture of mine:
    Wheel size on front question Leafsp10
    That first rectangular thing is a shim for setting the caster angle. Then there's that short, tapered leaf. Yeah, the third leaf would be good to remove because it doesn't have brackets.
    Wheel size on front question Leafsp11
    Post by Russell Mon May 02, 2016 9:08 am
    Wheel size on front question Int_0110
    Wheel size on front question Int_0111
    A couple of pix with the leafs removed, it looks like the 3rd one and the bottom small one.
    The Van had some removed when I got it so I mixed and matched what I had and some I got from Vanagain.
    Post by Twinpilot001 Mon May 02, 2016 9:20 am
    I even have 8 " wide wheels on mine-no mods!!
      Current date/time is Fri Apr 19, 2024 9:30 am
