Shocks for raised rear ends
cole63
Number of posts : 90
Post by cole63 on Sun Apr 03, 2016 7:04 pm
I had to raise my van in the rear 2" to clear some 15x10 slots in the rear. I now need new shocks. Does anyone have a part number on a set of shocks that will work? I searched here already, but came up with nothing.
Number of posts : 1897
Re: Shocks for raised rear ends
Post by Seth G on Tue Apr 05, 2016 7:58 am
Maybe fronts on the rear? Someone will know.
back2thewoods
Number of posts : 833
Post by back2thewoods on Tue Apr 05, 2016 10:52 am
air shock
uglylarry
Number of posts : 27
Registration date : 2015-09-23
Post by uglylarry on Tue Apr 05, 2016 11:55 pm
I have air shocks on mine.. If you'd like I can send you some photos
cole63
Post by cole63 on Wed Apr 06, 2016 4:24 am
uglylarry wrote:I have air shocks on mine.. If you'd like I can send you some photos
That would be great. Just looking for a part number so I can get a set.
Thanks, Cole
cole63
Post by cole63 on Wed Apr 06, 2016 4:25 am
back2thewoods wrote:air shock
Do you have a part number or remember the model you used?
Number of posts : 1367
Post by uante on Wed Apr 06, 2016 7:30 am
These are the ones I used on my van and I just lifted it 1.5" and don't have a problem with the rear shocks. Not sure if I'm at the limit of travel or not. The ones I got for the front are a little longer, but maybe ok in the rear if it's lifted. Notice the travel distances given in the item descriptions.
Rear
http://www.rockauto.com/catalog/moreinfo.php?pk=294396&cc=1334618
Front
http://www.rockauto.com/catalog/moreinfo.php?pk=294398&cc=1334618
rear shock installed
AthensTxMc
Number of posts : 61
Post by AthensTxMc on Sat Apr 16, 2016 3:51 pm
I called Monroe .. told them the compressed length and total length of the shock .. they gave me a part number .. I went to the local AutoZone and ordered a set .. Gabriel or any company should be able to do the same .. Air shocks tend to "bounce" ... They can probably just use the numbers from the stock application and ad the extra that you give to get you where you want to be ..
cole63
Post by cole63 on Sun Apr 17, 2016 7:05 pm
AthensTxMc wrote:I called Monroe .. told them the compressed length and total length of the shock .. they gave me a part number .. I went to the local AutoZone and ordered a set .. Gabriel or any company should be able to do the same .. Air shocks tend to "bounce" ... They can probably just use the numbers from the stock application and ad the extra that you give to get you where you want to be ..
Thanks for the tip. I plan on calling Monroe and telling them my situation and hopefully get a shock. I was being lazy and wondering if anyone had source readily available. haha
    Current date/time is Sat Jun 23, 2018 8:37 pm
