King Pins and other replacement steering parts
Matt Hagan
Matt Hagan
Number of posts : 48
Registration date : 2008-05-28
King Pins and other replacement steering parts Empty King Pins and other replacement steering parts
Post by Matt Hagan on Sat Mar 05, 2016 4:49 pm
I need to replace king pins and other steering parts. Where to get them? Rolling Eyes
Number of posts : 11710
King Pins and other replacement steering parts Empty Re: King Pins and other replacement steering parts
Post by donivan65 on Sat Mar 05, 2016 4:57 pm
If you got a G-10 and want bronze bushings, Rare Parts probably charges $137 for the kit,,,,,,,I got drag and center links for a G-10
Number of posts : 961
Post by VANagain on Sat Mar 05, 2016 7:20 pm
I took the easy route and went with the nylon bushings on my new king pins. That's what they came with. I'm sure the bronze ones are better but I hear they may need some machining to be properly fit.
Here's more info on king pins:
http://vintage-vans.forumotion.com/t909-king-pins-bushings#2404
Matt Hagan
Matt Hagan
King Pins and other replacement steering parts Empty Thanks
Post by Matt Hagan on Mon Mar 07, 2016 1:15 pm
Looks like I need to save some money! Thanks everyone for your 2 cents.
Post by donivan65 on Mon Mar 07, 2016 2:45 pm
,,,it wont be too bad if you go with the $45 Moog 8494N Nylon bushings that came in the vans,,,,,
ChevyVanMan1
Number of posts : 425
Post by ChevyVanMan1 on Wed Jun 15, 2016 3:24 pm
Although I'm oldschool and prefer bronze over nylon (Delrin actually a space age polymer) the old plastic spacers probably lasted for decades. Hence, as the bronze kits were so hard and expensive to get I went with plastic. However, I only use White Lithium Grease to lube my kingpins and other front end parts. I'm no chemist, yet I know WLG does not dissolve plastic and rubber like regular grease will over time. Hence, maybe the new set will last even longer--surely past my and my van's lifetime.
Number of posts : 831
Post by jrinaman on Wed Jun 15, 2016 3:43 pm
recently replaced mine, used the nylon and took a couple hours or less. wanted bronze but they need machined. local spring shop quoted $800.00 for bronze if I carry in the axle.
    Current date/time is Wed May 22, 2019 8:11 am
