need some HELP (ideas) on how to communicate between buildings...
chebby
Number of posts : 1727
Post by chebby on Tue Jan 12, 2016 8:25 pm
here's the situation... I live in a non-friendly phone signal area (have to climb a hill or go down the road to make calls)...  my boss (she's 78 years old, in poor health) wishes to be able to communicate with me (I live on the property) if needed...  right now we are using walkie-talkies because they are only so good and are powered only by batteries, she got the idea of CB radios...  I don't see that, needing antennas and all...  but I'm sure there is a solution
also she is thinking to possibly expand to other buildings, on the property and a bit further away...
does any one have any ideas of what kind of intercom system would work?  has anyone else used something like this before?
chebby Cool
I find it most disconcerting, to realize that the smartest member of our expedition is a dog (from Last of the Dogmen)
RF Man
Number of posts : 120
Re: need some HELP (ideas) on how to communicate between buildings...
Post by RF Man on Wed Jan 13, 2016 4:42 am
Your elderly boss actually has a good idea. CB radio's, however hoaky they may seem, are still an inexpensive form of communications. They use AM modulation and are authorized for more power than the little 2-way radios you get at discount stores. Professional 2-way radios( i.e. Motorola) have an effective range that is greater than the little cheap guys, but are pretty costly. Long range Wi-Fi communications gets even more expensive---and because of higher frequency, don't penetrate buildings well. You can only communicate in 2 ways---through wire or over the air(RF). Your solution is to find the cheapest RF----most likely CB.
Good luck Mike
Number of posts : 1340
Post by wideload on Wed Jan 13, 2016 6:50 am
No land line phones in the area??
Number of posts : 165
Registration date : 2011-07-28
Post by Zuffen on Wed Jan 13, 2016 1:43 pm
If the two buildings are on the same property why not run cables and use an intercom system.
It could be easily expanded to other buildings and they are quite cheap.
Number of posts : 483
Post by samsvan on Thu Jan 14, 2016 3:45 pm
What do cops use for their personal radios?
Number of posts : 2192
Post by EconoUSAparts on Thu Jan 14, 2016 4:49 pm
If you have internet signal use Skype or messenger call her thru facebook messenger.
Number of posts : 798
Registration date : 2014-10-14
Post by GMman on Fri Jan 15, 2016 5:29 am
A hand held CB radio is your best and cheapest option Chebby. When I lived down south, my friend and I used hand held CB's in our cars when we took trips back to Iowa.
http://www.grainger.com/product/UNIDEN-Handheld-CB-Radio-32RT59?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/32RT59_AW01?$smthumb$
http://www.ebay.com/sch/i.html?_nkw=handheld+cb+radio
chebby
Post by chebby on Fri Jan 15, 2016 8:47 pm
wideload wrote:No land line phones in the area??
we got landlines, yes (we're rural, not completely out of touch even though it may seem like it Very Happy )...  but I for one don't want to pay for landline service for myself just because...
chebby Cool
chebby
Post by chebby on Fri Jan 15, 2016 8:56 pm
RF Man wrote:Your elderly boss actually has a good idea. CB radio's, however hoaky  they may seem, are still an inexpensive form of communications. They use AM modulation and are authorized for more power than the little 2-way radios you get at discount stores. Professional 2-way radios( i.e. Motorola) have an effective range that is greater than the little cheap guys, but are pretty costly. Long range Wi-Fi communications gets even more expensive---and because of higher frequency, don't penetrate buildings well. You can only communicate in 2 ways---through wire or over the air(RF). Your solution is to find the cheapest RF----most likely CB.
Good luck Mike
thanks for the good info... I guess the since we have been using walkie talkies, is although they may work mostly for our purpose, problem is they are dependent on batteries.... I use rechargeable's and my charger seems to be in constant use because... (she was unhappy with her charger and batteries and returned them)...
do those hand held CBs come with a "base" for charging purposes? etc...
chebby Cool
chebby
Post by chebby on Fri Jan 15, 2016 8:59 pm
Zuffen wrote:If the two buildings are on the same property why not run cables and use an intercom system.
running cables is not an option... I was hoping someone knew something about wireless intercom systems...
chebby Cool
chebby
Post by chebby on Fri Jan 15, 2016 9:03 pm
EconoUSAparts wrote:If you have internet signal use Skype or messenger call her thru facebook messenger.
her puter is active 24/7 in her office... but I can't do that (I wish)... thanks for the idea Smile
chebby Cool
chebby
Post by chebby on Fri Jan 15, 2016 9:17 pm
GMman wrote:A hand held CB radio is your best and cheapest option Chebby. When I lived down south, my friend and I used hand held CB's in our cars when we took trips back to Iowa.
I see a possibility here! Very Happy
chebby Cool
Post by GMman on Fri Jan 15, 2016 11:06 pm
chebby
Post by chebby on Mon Jan 18, 2016 9:00 pm
you are a bucket load of knowledge on this! Very Happy
now "color me stupid" for just a moment...  isn't Includes a DC 12-Volt Power Cord the same as getting your power source from "the wall" vs by batteries?
chebby Cool
chebby
Post by chebby on Mon Jan 25, 2016 9:11 pm
hello... honestly... just want to make SURE on this "no brainer" really... Neutral
chebby Cool
    Current date/time is Mon Apr 23, 2018 6:13 am
