windshieldwasher pump
gregb
Number of posts : 83
Registration date : 2015-09-06
Post by gregb on Sun Oct 18, 2015 11:06 am
pump runs but wont suck, pretty simple system with the 2 little gears.
I even caulked to ensure no airleaks?
is this just a throw away thing ? are the pumps readily available ?
cheers
gregb
Re: windshieldwasher pump
Post by gregb on Wed Oct 21, 2015 2:25 pm
apparently the pump is not an original ??
Number of posts : 3757
Post by Digz on Wed Oct 21, 2015 4:44 pm
Thought someone would have chimed in by now . No that doesn't sound original. But it is impossible to find "original" new parts for the 1st gen pump that is normally mounted on the wiper motor. If some one has they haven't mentioned it and I have tried myself. Sounds like you have an aftermarket cure.
gregb
Post by gregb on Mon Oct 26, 2015 9:04 am
doigz - yea took me awhile to figure out it was original !!
guess i will keep windex in van for the big bugs !!
diamond dave
Number of posts : 565
Post by diamond dave on Mon Oct 26, 2015 3:35 pm
ive got a spare 2nd gen motor with pump setting in the garage. I bet theyre not the same, are they?
Number of posts : 1736
Post by m1dadio on Mon Oct 26, 2015 4:04 pm
The pump will only suck when primed. you need a check valve to keep it from draining back to the bag when not in use.
M1d
Post by Digz on Mon Oct 26, 2015 6:28 pm
diamond dave wrote:ive got a spare 2nd gen motor with pump setting in the garage. I bet theyre not the same, are they?
I'm not to up on the 2nd gen stuff so don't have a clue. I know a lot of stuff doesn't, although similar a lot of times is a No go for swapping.
    Current date/time is Tue Jun 19, 2018 6:20 pm
