Moving forward stepping back
rickland
Number of posts : 177
Registration date : 2013-10-14
Post by rickland on Fri Oct 16, 2015 5:34 pm
Hey, long time no see, been working on van, 1969 Chevy 108 restoration of a 1970 conversion
Took it camping this weekend in talimina ok, 292 with less than 1000 miles on it spun a bearing 2 miles from campground. I'm gonna post a pic before she trailers home for repair, I love this van.
Number of posts : 11605
Re: Moving forward stepping back
Post by donivan65 on Fri Oct 16, 2015 5:57 pm
So what bearing went bad,,,,,,,,I will probably be staying at the rest stop on I-40 in May, on my way to WideLoads in Kentucky,,,,,,,,
rickland
Post by rickland on Fri Oct 16, 2015 6:05 pm
rickland
Post by rickland on Fri Oct 16, 2015 6:09 pm
I'm not sure, guessing a rod bearing, spuratic knock and miss, removed valve cover everything up top looks good. Disappointing been having a good time with it. Interior redone in 1970 fashion, I'll try another pic. 6000 watt inverter, lights a/c ,tv ,wet bar,
Set at a body shop for 14 months before I gave up and picked up. I'm determined now.
rickland
Post by rickland on Fri Oct 16, 2015 6:12 pm
We live 6 miles off 40 at Shawnee, if you want a more quiet spot. Just let me know.
Post by donivan65 on Fri Oct 16, 2015 6:28 pm
,,,you might try to pull each spark plug wire off when running and see if any cylinder changes the noise,,,,,
Edoz
Number of posts : 18
Registration date : 2012-09-30
Post by Edoz on Fri Oct 16, 2015 7:18 pm
rickland wrote:
Dude, that van is cool as hell!
What campground did you stay at?
rickland
Post by rickland on Fri Oct 16, 2015 7:31 pm
I was afraid I would be doing more damage, no?
rickland
Post by rickland on Fri Oct 16, 2015 7:34 pm
We are at tahlamena state park Far East side of Oklahoma, 80 miles or so south of ft smith.
rickland
Post by rickland on Fri Oct 16, 2015 8:07 pm
Edoz
Post by Edoz on Fri Oct 16, 2015 9:18 pm
rickland wrote:We are at tahlamena state park Far East side of Oklahoma, 80 miles or so south of ft smith.
Nice, I've stayed there a couple of times.
Post by donivan65 on Fri Oct 16, 2015 10:19 pm
If you are worried about pulling off spark plug wires, you are doing the engine a favor if you have a bad rod or main bearing,,,,,,if you disconnect the spark plug wire, you dont have an explosion in that cylinder,,,,but if you have an engine miss also,,,,,bad bearings dont cause that,,,,,,you need to take a compression test,,,,,,a leak down test will check the condition of the rings and valves,,,,,,you just want to collect all the clues, see if something shows up out of the ordinary,,,,,,,before you blame the engine and tear it down,,,,,,,,
rickland
Post by rickland on Fri Oct 16, 2015 10:23 pm
Thank you, I'm curious to find out.
Post by donivan65 on Fri Oct 16, 2015 10:27 pm
,,,,all I can say is,,,,,,everyone here has an engine,,,,,,,show them what they got to look forward to,,,,,,,,and how to handle it,,,,,,
rickland
Post by rickland on Tue Oct 20, 2015 4:26 pm
Well, I will be forwarding pics over the next few days, it totally pisses me off to tell this but beware! I bought a small mr gasket air breather, mounted on one barrel, it appears the stud that holds the chrome top on with wing nut has backed off and been sucked into the number 4 cylinder where it is either laying on top of more likely embedded into top of piston, Spark plug gap was crushed.
Hopefully it's not done to much damage. It ran for a very short time.
Post by donivan65 on Tue Oct 20, 2015 4:37 pm
So I take it there is no compression on #4,,,,,,,,,nothing really cant get past the valves and into the cylinder,,,,,,unless the valve breaks,,,,,you might just get by with a valve job,,,,,
rickland
Post by rickland on Tue Oct 20, 2015 4:42 pm
Not that far along yet, but I suspect you are correct.
Number of posts : 1412
Post by Vantasia on Tue Oct 20, 2015 4:43 pm
rickland wrote:Well, I will be forwarding pics over the next few days, it totally pisses me off to tell this but beware! I bought a small mr gasket air breather, mounted on one barrel, it appears the stud that holds the chrome top on with wing nut has backed off and been sucked into the number 4 cylinder where it is either laying on top of more likely embedded into top of piston, Spark plug gap was crushed.
Ouch! It squeezed through the valve and got nipped off? I doubt the whole stud got through to the cylinder? Do the valves open wide enough for a 3/16" diameter shaft or wing nut to fit through? Maybe it jammed the valve or broke the valve and that's what's inside the cylinder and mashed the plug? You won't know until you pull the head. A valuable lesson, but chalk it up to Sh*t happens, not your fault, freak thing, we've all had stuff like that happen, at least no one got hurt....
rickland
Post by rickland on Tue Oct 20, 2015 4:56 pm
I'm anxious to get the head off maybe tonight.
Hoping for the best. Ready to work on the still broke stuff not the already fixed.
Oh, well. Off top of your heads anyone know if 250 and 292 oil pans enter change or is the oil pump pick up to deep or just won't work at all?
Post by donivan65 on Tue Oct 20, 2015 6:29 pm
I surely got a couple of junk 250 engines sitting in my back yard if you need pictures or measurements from,,,,
rickland
Post by rickland on Tue Oct 20, 2015 7:06 pm
I'm guessing you do, thanks for all your input, I'll post results as they become available!
Post by Twinpilot001 on Wed Oct 21, 2015 1:38 am
Heres a true story - I built a chev once -installed it in a 4 x 4 1947 jeep. Had a young mechanic install all the rockers & associated stuff. I made sure i had counted all rockers,balls & nuts!! before i had him do all. Comes tome & says - I need 1 more rocker nut! we searched everywhere- finally gave him another nut! Ran that jeep all over - a few years. that was in south texas - took it into canada with me -when i actually immigrated there in 1988! Was running it in a wonderful park one day. climbing hills & just enjoying that day - about 25 miles from camp!! Guess what?/ Found that rocker nut!it had fallen down & was on top of a valve all this time! finally went down into a cylinder & piston shoved that nut into the head & opened the water jacket area- overheating! Finally back to camp- removed the head & there it was! piston good -head replaced & away i went!! Twisted Evil If that young mechanic had been there - Id fed him to the bears!! affraid Twisted Evil
JOHNFIELY
Number of posts : 48
Registration date : 2012-08-30
Post by JOHNFIELY on Wed Oct 21, 2015 12:30 pm
I was in the big car show there at robbers caves in Wilburton last week end. it was great! I drove out there from norman.
rickland
Post by rickland on Wed Oct 21, 2015 12:54 pm
I
rickland
Post by rickland on Wed Oct 21, 2015 1:02 pm
You can looked great! let me know if you plan another we will dominate the scene, not a lot of vans in these parts yet.
Well, that's what is left of stud, cylinder seems to be fine, head doesn't look hurt its at at a head shop
Being torn down to insure there are no more pieces. Looks like it was all in #4 but there was a odd scratch in #3 but no debris. Hoping for the best. I'll post pic of breather, if you are using, check your stud, locktite, smash threads double nut. Thanks for all the advice.
    Current date/time is Wed May 23, 2018 1:39 pm
