350 engine
Patrick66
Number of posts : 13
Registration date : 2015-09-10
350 engine
Post by Patrick66 on Thu Sep 24, 2015 7:20 pm
"Please help." I would like to remove the 250 engine from my 69 "108". Will any year 350 engine fit into my van?
Last edited by Patrick66 on Fri Sep 25, 2015 3:24 am; edited 1 time in total (Reason for editing : no response or feed back from members.)
Number of posts : 483
Re: 350 engine
Post by samsvan on Fri Sep 25, 2015 7:17 am
Pretty much. You have a 2nd gen. van so the doghouse is the right one. If you're swapping transmissions too, you'll have to make a crossmember. Check out the search link for specifics.
Re: 350 engine
Post by Joe Van on Fri Sep 25, 2015 7:32 am
Welcome to VV Patrick66 ..!!!... cheers Any year Chevy 350 engine will bolt in but Imo I would stick from about 1985 and down to avoid the vortec style / fuel injected engines that way you can run a 600 cfm carburator and wont have to wire in a computer and various censors "Summit Racing" has some really nice crate engines all ready to go warranted and reasonable priced ....Good Luck... Smile
Number of posts : 11569
Re: 350 engine
Post by donivan65 on Fri Sep 25, 2015 9:36 am
The 1970 vans came with 350 engines,,,,,,,and with crossflow radiators,,,,,,,,they also had a special mount to hang a TH 350 transmission in it,,,,,,
Patrick66
Re: 350 engine
Post by Patrick66 on Fri Sep 25, 2015 11:54 am
Thanks everyone. That helps out tremendously.
Re: 350 engine
    Current date/time is Mon Apr 23, 2018 9:40 pm
