The Dodge Lodge
jseiff
Number of posts : 32
Registration date : 2015-09-11
The Dodge Lodge
Post by jseiff on Mon Sep 14, 2015 7:03 pm
Hey all. I was fortunate enough to pick up a 1967 A100 this summer. There's been obvious exterior cosmetic work done, but most stuff inside is original. And much of it still works. It's got a 318 with 97K on it. From the southwest, so little rust. There's no floor, ceiling, backseats...etc. This thing is just a metal box right now. I've got some big plans for this I will share along the way.
For now I'll share what I've had done to get this thing a bit more reliable:
- gas tank was rusted and patched several times. got it resealed inside and out and replaced sending unit.
- carb had crap from aforementioned rusty tank. cleaned and tuned up.
- point ignition upgraded to electronic.
- changed plugs and wires.
All the best,
Jordan
jseiff
Re: The Dodge Lodge
Post by jseiff on Mon Sep 14, 2015 7:33 pm
Number of posts : 9269
Re: The Dodge Lodge
Post by vanny on Mon Sep 14, 2015 7:46 pm
Welcome and Congrats on the sharp looking A-100! Can't wait to see more pics...If you're looking for ideas, you can click on the search tab and search any subject to find information. If you have questions, try to include details and pictures to help clarify. Lots of great helpful people on this site.
Number of posts : 3740
Re: The Dodge Lodge
Post by Digz on Tue Sep 15, 2015 2:51 am
Yes great looking van ! Have fun with it !
Number of posts : 1135
Re: The Dodge Lodge
Post by benwah on Tue Sep 15, 2015 2:24 pm
nice van!
Number of posts : 1688
Re: The Dodge Lodge
Post by westcoastvanner on Tue Sep 15, 2015 4:17 pm
Looks exactly what I want to make my van look like.
Re: The Dodge Lodge
Post by westcoastvanner on Tue Sep 15, 2015 4:22 pm
Sure looks like one that I have seen on the internet see below.
Last edited by westcoastvanner on Wed Sep 16, 2015 11:33 pm; edited 1 time in total
Re: The Dodge Lodge
Post by Big W on Wed Sep 16, 2015 9:33 pm
Welcome to VV. Great looking van you have there.
Re: The Dodge Lodge
Post by westcoastvanner on Wed Sep 16, 2015 11:34 pm
I love the black tint windows.
jseiff
Re: The Dodge Lodge
Post by jseiff on Wed Sep 23, 2015 6:03 am
Hi all,
I'd like some help identifying this plug under the van. I'm wondering if there's a block heater?
There's a power cord with female end at the front (accessible from under the grille). I followed it back where it's connected under the engine as shown below. Any ideas?
Number of posts : 7989
Re: The Dodge Lodge
Post by dix on Wed Sep 23, 2015 7:08 am
that would be a block heater , . it can be removed and the freeze plug reinstalled easily if it doesn't work or don't want it.
considering where you live that may be a good thing to keep.
Re: The Dodge Lodge
Post by vanny on Wed Sep 23, 2015 7:24 am
What Dix said. If there is no damage to the plug and it works, it's great in the winter. I used to have one on my 80's Chevy and if I plugged it in overnight in the winter, it would start up nice and smooth on those cold winter mornings. However, if the plug is damaged or if you're not going to be running it in the winter, there's no real need for it. So, if it's not damaged, I would just leave it "just in case" you decide to start it in the winter time on one of those cold Minnesota mornings! lol!
jseiff
Re: The Dodge Lodge
Post by jseiff on Wed Sep 23, 2015 8:20 am
Awesome, thanks for the replies. Was hoping it was a block heater!
The plug looks good but I'm not sure how to test it without waiting until a cold morning?
Number of posts : 766
Re: The Dodge Lodge
Post by panelmanrd on Wed Sep 23, 2015 10:44 am
neat device, but will not heat up a cold block just keeps a hot one warm
Re: The Dodge Lodge
Post by Big W on Wed Sep 23, 2015 8:17 pm
Best way to test that block heater is to plug it in and listen. You should here a quiet hissing sound. Most, if not all Canadian vehicles, come stock with block heaters. If you don't have it plugged in at -30...you are going to have a tuff time starting that engine. The one on your van is just to keep the antifreeze warm which helps keep the oil warm so it will start easier. The circulating block heaters actually keep your antifreeze flowing as if the vehicle is running, and heat the engine to a hotter temp then just a regular block heater ever will. I have a circulating one on my snowplow and when I start the plow up I have hot air blowing through the vents Immediately.
jseiff
Re: The Dodge Lodge
Post by jseiff on Wed Sep 23, 2015 8:51 pm
Thanks big w.
What kind of current/power does it draw? Curious about powering it from an auxiliary battery with an inverter for a couple hours prior to start.
jseiff
Re: The Dodge Lodge
Post by jseiff on Wed Sep 30, 2015 8:01 pm
The latest task I completed was taking apart the doghouse to repaint and reinsulate. More pics to come.
I used Rustoleum High Heat (up to 2000 deg) flat black for the outside.
And I used this insulation for the inside.
I also applied a weather strip to the base (between the doghouse panels and the floor). Replaced some of the hardware too.
I've also installed new lap belts.
mo_1040
Number of posts : 638
Re: The Dodge Lodge
Post by mo_1040 on Thu Oct 01, 2015 6:18 pm
Where about in Minnesota are you?
Re: The Dodge Lodge
Post by benwah on Fri Oct 02, 2015 9:10 am
Years ago I had one of those oldsmobile 5.7 converted diesels in a 81 gmc truck. ( No need for sympathy cards. ) It had a block heater. (I spent a lot of time under the hood I should know.) I put it on a timer so the block heater would rev up two hours before I could swear at the truck. (I mean try to start.)
to save on electricity. Now mind you I don't live in Fargo. It does get cold in new england. 10 F the truck would whirl over pretty fast. I never tried running 50 miles of extension cord to get to work. (maybe that might have helped.) I do know it made a differerance. I had a case of ether on the passenger floor so when I got out of work I could try to start the truck. Most of the cold evenings I went home with the secretary, the only fun thing about owning that truck!
jseiff
Re: The Dodge Lodge
Post by jseiff on Fri Oct 02, 2015 5:16 pm
@mo_1040 Twin Cities
jseiff
Re: The Dodge Lodge
Post by jseiff on Sun Oct 11, 2015 7:25 pm
New insulation on inside of the doghouse.
jseiff
Re: The Dodge Lodge
Post by jseiff on Sun Oct 11, 2015 7:27 pm
UPDATE! We've had some great fall weather here in the upper Midwest so I've been taking advantage of it. I have started turning this DODGE into a LODGE.
These photos show the progress of the flooring. Here are the layers:
- sound deadening RAAMmat
- underlayment padding
- 1" foam board insulation
- 1/2" OSB as subfloor
I plan to install a vinyl or laminate floor as the final layer. Other work to do first!
Re: The Dodge Lodge
Post by vanny on Mon Oct 12, 2015 5:42 am
Nice work. That should quiet things down for sure! Thanks for posting pics. Nice to see the steps taken to get things done. Very Happy
Re: The Dodge Lodge
Post by westcoastvanner on Mon Oct 12, 2015 6:57 am
What is the brand name of the foam board that you used and where did you get it?
jseiff
Re: The Dodge Lodge
Post by jseiff on Mon Oct 12, 2015 8:12 pm
westcoastvanner wrote:What is the brand name of the foam board that you used and where did you get it?
Foamular. 1" thick, 150 density, R-10. Got it from Home Depot in 4' x 8' pieces.
Re: The Dodge Lodge
    Current date/time is Mon Feb 19, 2018 7:59 pm
