66 front end options
Vmaverickv
Number of posts : 1
Registration date : 2015-08-30
Post by Vmaverickv on Tue Sep 01, 2015 6:42 am
I'm new to the van world and have just acquired a 66 g10. I would like to get away from the leaf springs in the front and was wondering what opinions/solutions some of you guys had. If there is a previous post please drop me a link
thanks in advance
1966G10
Number of posts : 138
Registration date : 2009-10-14
Re: 66 front end options
Post by 1966G10 on Tue Sep 01, 2015 9:28 am
Why would you want to get rid of the leaf springs? Leaf springs have worked fine for over 80 years now.
Xelmon
Number of posts : 343
Post by Xelmon on Sat Sep 12, 2015 1:02 pm
Hoooyyy I've seen a conversion or two. I would honestly advise against conversion job, unless you are dead-set on it and willing to do a lot of testing and fabrication.
Still, newer solutions include torsion spring, MacPhearson, and double wish-bone.
I can't imagine how would effectively do torsion springs. At that point you would either go with MP or double wish-bone suspensions. Difference between them is MP deletes the upper wish-bone, which makes it lighter and less complex, at the cost of long-term durability.
Your No 1 hurdle is building strut towers, as there is only thin sheet metal in the wheel well. This would mean that you would have to build a box-beam tower and suspension attachment points, which is lots of cutting, welding, and fabrication.
Your No 2 hurdle that you'd have to figure out before that is geometry of your suspension. Do it incorrectly and due to caster your wheels chamber could be positive, which is pretty bad as that reduces your tire-patch. Your van also squats a lot more with independent front suspension, so you'd also have to account for that too.
Your No 3 hurdle is the spindle, which you would have to adapt from somewhere, by my guess a K5 or as such. However off hand I really don't know how difficult that would be.
All of this that I described is basically advanced fabbing and entry / mid-level automotive engineering so that you would end up with a stable vehicle.
Post by Twinpilot001 on Sat Sep 12, 2015 4:16 pm
1966g10 is correct!!  seems  if i remember - the steam cars in the late 1800's used them too?? Wernt  those leafs on stage coaches & buggys too? Even under the seats? Think  now - we need to re-invent the wheel!  affraid
Stability =is the key & ease of building all!! Lets see??- If I remember correctly?? = Its better to have a "Bottle -in front of me -Than a =Frontal Labotamy!"" affraid cheers lol! lol!
    Current date/time is Tue Jan 16, 2018 7:07 am
