Looking to see if anyone has a Carter YF carburetor they would like to sell. For my 66 Sportvan. Where my fuel line goes in the aluminum is stripped and doesn't tighten up. I really only need the top end but if i need to I will buy the whole carb.
Carter YF Top End
1966G10- Number of posts : 138
Registration date : 2009-10-14
Carter YF Top End
- Number of posts : 12218
Re: Carter YF Top End
Check the parts store,,,they make oversized repair fittings for carbs,,,,
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Carburetor-Inlet-Repair-Fitting-Inlet-Size-1-/_/R-CRB275_0430138653
I will have to give that a shot, thank you. Such a let down, trying to get it running and everything and then it doesn't seal up. But thats the name of the game I guess.
Look on ebay, lots of old YF needing rebuilding you could get for parts. there are also several rebuilt ones for high dollar but contact those sellers and see if they have some old cores they'd sell you, most are freindly and helpful. try doni's idea first.
