,,,,and there in lies the problem.......disk brakes need 800 psi to operate,,,,,drums need 500,,,,,
so when you slam on the brakes, as soon as the master cylinder gets to 500 psi, the drum brakes are full on,,,,while the disks are 1/2 on, just slowing down,,,,,,and for a vehicle to stop right, the fronts need to do 60% of the work, while the rear does 40%. And disks need a booster to let that master cylinder get to 800 psi,,,,,,,and the way I see it, disk brakes wont stop you faster than drum brakes,,,,,I had customers complain about brake problems on brand new vehicles when they had disk brakes without a booster,,,,,but they sure are lower maintenance and let you stop straighter, just not faster,,,,,I put front disks on my 65 Chevy Van with a 71 Chevy Van combination valve,,,the factory valves are matched to each vehicle,,,we are inventing the system,,,,they are non adjustable,,,,and got more different lines going to it,,,,they have the residual check valves in them to prevent low pedal ,,,,,so one of those simple adjustable ones might be a better choice,,,,,unless someone found parts that work together.......
