    Trans Bushings?
    Trans Bushings? Empty Trans Bushings?
    Post by Guest Wed Mar 18, 2009 6:41 pm
    The transmission linkage keeps getting caught up in my van. I've heard the problem is worn out bushings of the linkage conections at the bottom of the coloum.I was wondering if anybody had a part number for these or knows where I can get them. Let me know,
    -Ryan
    Number of posts : 12218
    Trans Bushings? Empty Re: Trans Bushings?
    Post by donivan65 Wed Mar 18, 2009 11:29 pm
    I would say that the bushings are GM 3975132. but you might be able to go to a radio installation shop or Radio Shack and get a rubber grommet that will fit.
    Trans Bushings? Repair12
    Post by Guest Thu Mar 19, 2009 2:47 pm
    Thanks for the p# Donivan. Its listed on GMpartsdirect for 81 cents! Thats probably the cheapest fix i'll make.
    Post by donivan65 Thu Mar 19, 2009 3:00 pm
    You might want to call them to see if they are the right ones,,,,and see what the packs of 20 costs,,,,,,,,,,,,,Each van would probably take 8 of those 1/2 grommets..... And the carb linkage probably uses these also,,,,,,,,you might want to buy a bunch,,,,,the Chevy guys here would buy them from you,,,,,,
    Post by Guest Thu Mar 19, 2009 3:21 pm
    Will do.
    shorty
    shorty
    Number of posts : 135
    Registration date : 2014-01-01
    Post by shorty Sun Jul 26, 2015 6:19 am
    Are these the same as the powerglide bushings?
    Number of posts : 1412
    Post by Vantasia Sun Jul 26, 2015 7:27 am
    The split bushing is a must, you put one on each side and slip the rod yoke over them.  Its near impossible to push a whole grommet style through the holes unless the shifter is out and in hand.  I just did mine at both ends with the correct NOS GM ones.  The rear are grommet style with a 1/2" hole and 1/4" wide slot, some NOS ones are around....the rear also have a pair of thin, I think they are like .020", spring steel thrust washers on each side of them that are always missing, they keep the bushing from twisting and tearing up when you shift.  I found them at McMaster industrial supply.
    Post by donivan65 Sun Jul 26, 2015 10:53 am
    shorty
    shorty
    Post by shorty Sun Jul 26, 2015 10:59 am
    Donivan, are these for the 3speed manuals and powerglides?
    Post by donivan65 Sun Jul 26, 2015 11:06 am
    These are for pick ups,,,,,,,you need to measure what size holes and rod size you got,,,,,and maybe someone generous here in the Los Angeles area can go over to this store and give them 50 cents and slap it in an envelope to you to solve one of our problems,,,,,,,
    Post by Vantasia Sun Jul 26, 2015 11:52 am
    Pretty sure the split ones listed for 67-72 fits the 1st gen and that's the one's I used in the front, but like Doni says, see if the center hole is the same size as the front rod pin.  I tried the one piece shown from Dorman, same bushing, but they are nearly impossible to push through the hole laying on your back, the spilt ones go in in seconds.  Its also fishy because it says "four" required"?, you only need two one piece, the four halves would be for the split style, the shop manual shows the split style for 1st Gen vans, View A shown below.   Here is an original 1st Gen rear rod bushing, its a hard rubberlike grommet and the replacement washers I found for the ones shown in the manual View C scanned below.  Regular steel 1/2" washers are too thick and will bind.  I used a combination of the .031 and .047's.  I still have 6-7 of each since I had to buy them in ten packs, so if you are missing them, PM me and I will be happy to share a few while they last...MAC over at VCVC had a supply of the rear grommets but they should be available somewhere too, its 1/2" ID with a 1/4" wide groove.
    Trans Bushings? Gedc1620
    Trans Bushings? Gedc1621
    Trans Bushings? Scan0011
    Trans Bushings? Scan0012
      Current date/time is Thu Apr 18, 2024 9:21 pm
