    Dual master
    slik
    slik
    Number of posts : 57
    Registration date : 2015-06-04
    Dual master Empty Dual master
    Post by slik Thu Jul 09, 2015 10:54 am
    I'm replacing my whole break line and turning my single cylinder into a double cylinder.
    I have a 1966 Dodge a 100 which came stock the single cylinder master. What would I do to purchase a dual master? Can anyone steer me in the right direction on the part?
    Thanks
    Number of posts : 12218
    Dual master Empty Re: Dual master
    Post by donivan65 Thu Jul 09, 2015 11:51 am
    slik
    slik
    Post by slik Thu Jul 09, 2015 4:27 pm
    Awesome thanks!
    Post by donivan65 Thu Jul 09, 2015 6:02 pm
    ,,,now lets see what the Dodge guys say about installing it,,,,,,,,on my Chevys, I need to cut part of the bracket to put that longer master cylinder in it,,,,,,,,,but thats the best thing you can do,,,get rid of that suicide 1 line and put in a 2 line,,,,,change the old brake lines and hoses while you are at it,,,,,,
    Post by donivan65 Thu Jul 09, 2015 6:06 pm
    I just buy these wire wound Napa brake lines that dont require a tubing bender and run new lines,,,,,,
    this is a Chevy parts list,,,,,,,
    Dual master Brake_14
    slik
    slik
    Post by slik Thu Jul 09, 2015 6:10 pm
    Yeah thx. I'm going with nickel copper lines. Replacing everything. My lines are rusted and brittle. I was wondering a dual would fit it if I'd have to cut to make room. But that's what I'm doing. I'm going to upgrade to dual. Can't afford a disc upgrade so sticking w drums.
    Also has anyone ever cut an access hole under there seat? I think the master is under the drivers seat. Why not cut a good looking access area out. Sure would make working on cylinder a piece of cake in the future and the access hole would be hidden by the seat. Of course with a cool cover on it.
    Post by donivan65 Thu Jul 09, 2015 6:15 pm
    you dont have to on a chevy,,,,,there is enough room to put your hand down there, to unsnap and remove the cover, every 3 years when you get around to checking the fluid level,,,,
    Post by Guest Fri Jul 10, 2015 9:16 am
    I have a 69 A100 that needed a new master. Being that it was already a 2 line system was a easy swap. Just get yourself a  67-69 master cylinder and marry it up. Just a FYI, I got mine at NAPA and the one they gave me wouldn't fit, I would have to cut, plus it looked a lot different. It took a couple try's to get the right one but finally got it. In other words, you shouldn't have to cut a thing if you get the right part!
    slik
    slik
    Post by slik Fri Jul 10, 2015 10:14 am
    Ok great!  Does anyone have a pic or a link to the exact replacement for that year dual master?  Then I could match it up before I buy.
    Henrik
    Henrik
    Number of posts : 156
    Post by Henrik Fri Jul 10, 2015 10:01 pm
    Dual master 20150311
    Sorry that the picture is the wrong way,im posting this from my phone cant rotate it
    This is how i ended up doing mine.
    You have to make the hole a lot bigger than what it is to make the mc to fit.
    I reinforced the construction with flat metal.
    Post by donivan65 Fri Jul 10, 2015 10:17 pm
    Slik,,,that is a disk brake set up
    Henrik
    Henrik
    Post by Henrik Fri Jul 10, 2015 10:27 pm
    This is a drum brake setup with heavy duty front axle that has the bigger drums.
    Raybestos part number is mc36221
    Post by donivan65 Fri Jul 10, 2015 10:44 pm
    So he wont be needing that proportioning valve,,,,,,,,how long is that master cylinder,,,,,,and he will probably have to invent some kind of brake light switch to install a dual line master cylinder in his single line system,,,,,,,,
    Henrik
    Henrik
    Post by Henrik Sat Jul 11, 2015 12:34 am
    I used the old brake light pressure sensor. I installed it in the old junction that divided the front and the back when it was single system
    slik
    slik
    Post by slik Sat Jul 11, 2015 4:33 am
    Thanks all. I was wondering if the 67s on had been different that allowed more room for the new cylinder. I'm just gonna order the part n go from there. I'll post pix in my thread in general discussions a vans
    Post by vanny Sat Jul 11, 2015 4:41 am
    Maybe 69A100 could post a pic of his since he said he didn't have to alter anything. If there's something that works with no or "minor" alterations, that would be the route I'd take! JMTC! Very Happy
    slik
    slik
    Post by slik Sat Jul 11, 2015 5:04 am
    Yeah. I'd love to know the part he had that fit without cutting. Thanks.
    Number of posts : 1605
    Post by itruns Wed Jul 15, 2015 6:31 pm
    If I don't do a disc brake conversion, I'll probably get this one
    http://www.summitracing.com/parts/aaz-10-1323
    Post by Guest Fri Jul 17, 2015 3:43 pm
    I have the one on the right, I got it a NAPA. I couldn't find it on their site, that's why this one is here. If I remember right, the one on the left has a height issue against the floor with the raised top. Think of a low profile height master cylinder and you'll win. Good Luck
    http://www.oreillyauto.com/site/c/search/Brake+Master+Cylinder/01292/C0066.oap?year=1969&make=Dodge&model=A108%2BVan&vi=1404177
      Current date/time is Thu Mar 28, 2024 1:32 am
