Rear sway bar mounting: Calling Donivan
- Number of posts : 12218
Thanks Don ! That's what I needed to see. I didn't really like the idea of welding more to the frame. That saddle mount style should fit the bill. Good chance I'll have to swap to some longer links also.
Thanks again.
Thanks again.
Jim_Rockford- Number of posts : 25
Registration date : 2015-06-21
Looks like your brackets are backwards putting too much side load on the end links
Well,,,,,these vans did not even come with front sway bars let alone rear ones,,,,,they are used on coil spring suspensions to prevent leaning on turns,,,,,,,this one is off a 85 Firebird, costing $11,,,,,I think my rear sway bar has an easy life back there,,,,,I have a front sway bar, 7 leafs in the rear springs, and rear air bags,,,,,,so I doubt those links ever get any use,,,,,,if there was a problem, I think the link would bend the frame bracket into a different position,,,,,,,
I still have a chunk of 3 x 6 box tubing I will cut up for the frame wrap and possibly the drops if clearance allows. Did you just run some 5/16" or 3/8" bolts thru the frame Don ?
The sway bar is really a torsion bar,,,,,made to twist when one link pushes down on one side which causes the other to pull the frame down as the van leans,,,,,they are like a rubber band,,,,,so basically they are there to keep the van standing straight up,,,,,I doubt that there is a lot of pressure on everything back there,,,,I used 5/16" bolts right through the frame,,,,,,2nd Gens are kind of like riding on a waterbed with their soft springs,,,,and you got the HEAVY DUTY 3 leaf ones,,,,,,they surely can use sway bars,,,,,,SportVans are the ones that come with front sway bars,,,,,our 1st Gens ride pretty rough with their 6 and 7 leafs in back,,,,,,the link spacers are made from 1/2" solid electrical conduit
savage- Number of posts : 2625
Joe ,here 2 pics from Toms(Milwright71) sway bar on his 66 . Hope it helps.
