first gen master cylinder reservoir filler hole cover ?
sparky
Number of posts : 195
Post by sparky on Fri Jun 12, 2015 6:29 am
are these available anywhere  ? when it's cold outside that wind coming up thru that hole
Last edited by sparky on Fri Jun 12, 2015 5:15 pm; edited 1 time in total (Reason for editing : because....)
AzDon
Number of posts : 322
Re: first gen master cylinder reservoir filler hole cover ?
Post by AzDon on Fri Jun 12, 2015 6:18 pm
I'd be surprised if that is available....... You could either make something or..... get a screw-out deck-access-plate from a marine supply like West marine.......It's a beveled screw-down ring with threads inside and a screw-in lid.....They are intended as waterproof access ports for boats, so they have a rubber o-ring and are water tight... They are available in different sizes and are perfect for access anywhere you just need to get your hand ie; radiator cap, dipstick, etc......There are even versions with a clear lid if you have something where visual monitoring is a need....
Number of posts : 1732
Post by m1dadio on Fri Jun 12, 2015 11:53 pm
There are round covers like that used on three or so different GMs and Fords in the 50's and 60's.
I don't think anybody has tryed to find a match to the first gen.
M1D
Number of posts : 1412
Post by Vantasia on Sat Jun 13, 2015 6:21 am
Big thread on this over at VCVC, no one has found a replacement plug from any vintage car GM or other that fits perfect, just make one from something, a couple of pieces of 1/4" rubber sheet, a larger piece on top to fit the lip will work fine, a plastic paint can lid, plexiglass disc, the boat plug mentioned, etc...be creative. If its under carpet or a mat, no one will see it...There was talk of reproing them or a 3D printer making a plastic one but it went nowhere....
back2thewoods
Number of posts : 831
Post by back2thewoods on Sat Jun 13, 2015 6:35 am
I used a round elec. box cover
bletman
Number of posts : 50
Post by bletman on Sun Jun 14, 2015 4:05 pm
I used sheet metal.
AzDon
Post by AzDon on Mon Jun 15, 2015 1:56 pm
I remember the original plug on my 66 as being thick above the floor, a real pain to stuff into the hole and not easy to get out, unless you wanted it to stay in.... I can think of half a dozen better ways to securely cover the hole, several of which wouldn't require drilling any holes in the floor....
Number of posts : 483
Post by samsvan on Mon Jun 15, 2015 2:25 pm
I put some KY jelly on mine and now it slides in and out real nice...
Post by Vantasia on Tue Jun 16, 2015 5:50 am
bletman wrote:
I used sheet metal.
Perfect, all ya need! Did you put a gasket under it?
bletman
Post by bletman on Tue Jun 16, 2015 8:09 am
Yes - I cut a gasket from and old bicycle inner tube.
    Current date/time is Sun Apr 22, 2018 7:15 am
