Holly 4 bbl carb ???
gkpost
Number of posts : 223
Post by gkpost on Sat Jun 06, 2015 2:39 pm
I put a holly 390 on my 250 inline 6. I had to lower the motor and all that .
So my question is what the hell am I supposed to use for an air filter/cleaner?
Do I have to make one? Is there some k&n kit that can be retrofitted?
someone has done this and I could use a little help. Thanks for any input.
~ GK.
Number of posts : 1878
Re: Holly 4 bbl carb ???
Post by savage on Sat Jun 06, 2015 3:53 pm
WOW,I like to see pics of that. I would think you have Alot more room on a 2nd gen.
Maybe a 4 in single plenum(865-9849) to 4 in flex ducting(865-9751) to 4 in intake filter(865-9732) Jeggs part numbers
Number of posts : 3752
Post by Digz on Sat Jun 06, 2015 7:54 pm
A "bonnet" and a tube to a K&N type filter might do the trick if there is room for it.
This was an EL Cheapo made in messico but I have seen some brand name types that do the same thing and maybe better fit..
Number of posts : 1293
Post by Lazarusvan on Sat Jun 06, 2015 8:43 pm
Are you using a carb spacer? Mine had one in place which we removed and we are now looking for something that will allow a nice, fat filter to go in place.
The previous owner had just crunched down a larger filter to make it fit. Nothing good about that. I couldn't find the right size filter previously and I'm looking for the right thing to clear as well and still give me a tall filter at the same time.
I have a dropped down motor as well and 2nd Gen doghouse.
Xelmon
Number of posts : 343
Post by Xelmon on Sat Jun 06, 2015 11:13 pm
Oh huh, that looks pretty sick!
gkpost
Post by gkpost on Sun Jun 07, 2015 5:39 am
I do have a carb spacer, I need that to rotate the carb 90 degrees for my throttle. I've got plenty of room on top , but only 1/4 inch to one side. I'm love'n that tube to a bonnet set up.
what is that tube? Is that a k&n product?
Post by Digz on Sun Jun 07, 2015 1:19 pm
Look up spectre products. They are pricey. Check eBay for dodge truck cold air intake. Believe I only paid 16$ for base kit. The angles from Spectre cost much more.
    Current date/time is Sat Apr 21, 2018 7:55 pm
