questions on V8 swap and transmissions
GiraffeSquad
Number of posts : 12
Registration date : 2014-04-09
Post by GiraffeSquad on Wed Apr 29, 2015 10:58 am
Hi everyone I have a 69 chevy g10 that has been my project car. Up until now I have just been cleaning it up and getting it rolling again, but now the bug has bit me and I want to do a lot more. I just finished doing a custom lift and putting on some big ol 31in tires. And of course now my issue is I want MORE POWER. I have always wanted more but now I need it. I don't really want to regear because I like taking it on the highway without the rpms revving up so high. So anyway to get back on point I currently have the 250 inline six with the 3spd tranny. My questions are
Can I fit a 350 with no doghouse modifications?
Whats a good transmission to mate with a 305 or 350 in this van (I want to keep in manual)
I know plenty of people have done the swaps and iv been trying to search for them but any search I type in today on the forum for some reason comes up with 0 results.
Thanks for the help, oh and here is my van.
back2thewoods
Number of posts : 830
Re: questions on V8 swap and transmissions
Post by back2thewoods on Wed Apr 29, 2015 12:55 pm
yes a v-8 will fit in motor box, youll need to upgrade radiator
Post by Joe Van on Wed Apr 29, 2015 5:50 pm
Welcome To VV..!!!.. cheers ..I will second that the 1967-70 Chevy & GMC Van's are set up for the V8's its the 1964-66 that have the smaller motor box.."Good Luck" on your project.. Smile ..
Number of posts : 9098
Post by vanny on Wed Apr 29, 2015 6:33 pm
Did you try typing in swap in your search? Seems to pull up a lot for me! Anyway, really nice looking 2nd Gen you've got there and it looks like you've done a Fantastic job of tidying up the engine compartment!!! Can't wait to see the results of your efforts! Good luck and keep us up to date with pics,,,,PLEASE! Very Happy cheers
Number of posts : 766
Post by panelmanrd on Thu Apr 30, 2015 6:51 am
a v8 any small block chevy will fit in the dog house
and will bolt up to the trans that is in there, just need
to improve the cooling sys (more capacity) and you will
have to modify the throttle to work with the v8. use the
mounts that are bolted to the brackets on your 6 they
bolt to the v8.
GiraffeSquad
Post by GiraffeSquad on Thu Apr 30, 2015 7:15 am
Thanks for all the info guys. So next questions, I assume to do the swap I will have to cut off the doghouse? After would it be smart to make a quick release system to take it off for service later? or just weld it back up. Also as far as the radiator goes How do I figure out what size/capacity I need and where would I mount a larger one?
Number of posts : 1392
Post by Vantasia on Thu Apr 30, 2015 8:07 am
With a 2nd gen doghouse, you should be able to install a SB 8 without modifying the doghouse in any way. Probably have to be jacked up into place on a lift, not drop in from the top with an extended hoist.
Post by panelmanrd on Thu Apr 30, 2015 10:53 am
When installing the v8 remove exaust manifolds, valve covers,
and fuel pump and it will go in from the side doors either front or
the side cargo right down through the opening of the doghouse
with no mods to the doghouse. just have to have the chain short
so the cherry picker is very close to the engine, carb plates work
the best for v8s.
kookykrispy
Number of posts : 1452
Post by kookykrispy on Thu Apr 30, 2015 11:04 pm
I have done a couple v8 conversions into 1st gens using 2nd gen doghouses. I always cut the DH vertically, just aft of the radiator, and then make the aft portion removable. Makes engine swaps so much easier, and its really nice to be able to have full access to your engine for changing plugs, or working on exhaust manifold/headers. I have a '69 sportvan with a factory v8 with non-cut doghouse and it is a pain in the ass to get at the plugs and the manifold bolts.
As far as transmissions go, since you want to stay with a manual trans, you can simply keep your stock 3 speed. The bellhousing will bolt onto a v8.
On your v8, you'll need to check and make sure the block has the hole drilled & threaded for the clutch pivot ball. Some v8 engines have the boss, but it is not always drilled & tapped. I put a 400 SBC in my '65 and had to drill & tap the boss for the clutch pivot ball to thread into. Make sure to check on this and if needed, drill & tap the hole while your engine is on an engine stand before you install it into your van.
Bear
Number of posts : 849
Post by Bear on Fri May 01, 2015 6:20 am
good looking van
Number of posts : 381
Post by Russell on Tue Aug 09, 2016 7:12 am
kookykrispy wrote:I have done a couple v8 conversions into 1st gens using 2nd gen doghouses. I always cut the DH vertically, just aft of the radiator, and then make the aft portion removable. Makes engine swaps so much easier, and its really nice to be able to have full access to your engine for changing plugs, or working on exhaust manifold/headers. I have a '69 sportvan with a factory v8 with non-cut doghouse and it is a pain in the ass to get at the plugs and the manifold bolts.
I'm looking for some tips on how to swap my 1st gen 6 to a V8 and later doghouse, do you have a link with info? what to do,what not to do etc.
kookykrispy
Post by kookykrispy on Tue Aug 09, 2016 9:27 am
woah! zombie thread!!! haha
Well, what I did was cut the doghouse and floor tunnel out of a 2nd gen. make a vertical cut aft of the radiator. weld in the front section and the tunnel. Use fasteners to make the rear of the box removeable.
Sorry I do not have a link, but maybe next 1st gen v8 conversion I do I will make a good 'how-to' thread
Number of posts : 346
Post by JackeFriend on Tue Aug 09, 2016 9:57 am
kookykrispy wrote:woah! zombie thread!!! haha
I am swapping out my 1st gen doghouse with a 2nd gen V-8 from a '68. My GMC 64 has a 350 with Q-jet. I am glad I found one, doghouse's are not easy to find, and switched it. The 6 doghouse is way to small for a 350 unless you really modify or swap out. Check out my posts... not everything lines up and it is a bit of lets see. Good luck!! Basketball
chiliVANilli
Number of posts : 30
Registration date : 2014-10-21
Post by chiliVANilli on Sat Aug 13, 2016 8:54 am
Mine went in with no problems, except I had to modify the Dog house for my alternator, because mine uses the stock serpentine belt set up. I can try to find the part # for the radiator I used, but I know it was from Champion. I had to modify the Dog house so I could get the cap off. I agree on doing something to access the spark plugs, especially on the passenger side, it's a total pain in the a$$ to get to them. I'm pretty sure it's all on my build thread on expeditionportal.com. I'm pretty sure you have seen it there. I wish it wasn't raining so hard when you were here. Let me know if you need pics, I still have your#. Nice van by the way!
chiliVANilli
Post by chiliVANilli on Sat Aug 13, 2016 8:57 am
Oh yeah, I removed the front axle and dropped the Van over the engine. I was trying not to cut the Dog house.
Pats 69 G10
Number of posts : 51
Registration date : 2016-06-07
Post by Pats 69 G10 on Tue Aug 16, 2016 6:19 pm
Do you have plans for your 250? I need one for my 69 G10. I'm too old for the v8 swap Smile
just want to get on the road...
    Current date/time is Sun Jan 21, 2018 8:32 am
