    framing in and installing paneling in rear corners.
    steelrat
    steelrat
    Number of posts : 116
    Registration date : 2014-11-24
    framing in and installing paneling in rear corners. Empty framing in and installing paneling in rear corners.
    Post by steelrat Thu Apr 23, 2015 5:17 pm
    How have you all framed in and installed paneling in the rear corners? Have you box framed them, done an angle across, or? Any pictures would be appreciated. I want to be able to access rear brake light bulbs  if needed. Some little hinged doors. Got majority of the van framed out so far.
    framing in and installing paneling in rear corners. Img_2062.
    framing in and installing paneling in rear corners. Img_2063
    Thanks
    Shaun
    Number of posts : 864
    framing in and installing paneling in rear corners. Empty Re: framing in and installing paneling in rear corners.
    Post by Casimier Sun Apr 26, 2015 5:16 am
    Hey Steelrat
    The easiest way when I did my vans was to make a square removable panel full ht.
    Run your side paneling as far as possible back into the corner.
    Block with some 1x2 on top of the panel to accept the new panel which will come off 90 degrees.
    The new rear panel will have to be contoured to the shape of the side wall.
    Screwed to the 1x2 blocking and screwed to the frame next to the door for removal.
    That's as simple as it gets.
    Jim in NJ aka Casimier
      Current date/time is Thu Mar 28, 2024 7:37 pm
