1st Gen or 2nd Gen Gas tank bolts
EvilToywarz
Number of posts : 35
Registration date : 2014-06-16
Post by EvilToywarz on Fri Apr 03, 2015 11:16 am
Hello, does anyone have a good used set of gas tank "J" bolts I could buy? I snapped one off yesterday removing my gas tank on my 68 Chevy sportsvan. Thanx!
Number of posts : 11492
Re: 1st Gen or 2nd Gen Gas tank bolts
Post by donivan65 on Fri Apr 03, 2015 1:41 pm
Well,,,,,,,,a 6" piece of 3/8" threaded rod or carriage bolt can be heated up and bent to do the job,,,,,this one just might be sitting under my front seat at EconoWest on the 19th,,,,,,,,
EvilToywarz
Post by EvilToywarz on Fri Apr 03, 2015 2:08 pm
Hey,
Thanx for the info and reply....do you know any 1st or 2nd gen parts vans? I am in need of several parts...
Looking for a set of vent window frames for my 64 and the lower window channel bar for the passenger side front door on my 68. It is completely missing, not sure why? My window rolls up and down like crap.
Any help would be great!
Casey
951 329-7500
kookykrispy
Number of posts : 1452
Post by kookykrispy on Fri Apr 03, 2015 5:17 pm
EvilToywarz wrote:the lower window channel bar for the passenger side front door on my 68. It is completely missing, not sure why? My window rolls up and down like crap.
Look inside the door, in the bottom! Often the glue separates from the glass and the window channel bar falls down inside the door.
Post by donivan65 on Fri Apr 03, 2015 5:29 pm
the vent glass channel guides the front of the glass up and down,,,,,,the backside of the glass is guided on top by the rubber molding while a channel that is bolted on on top and on the bottom of the door, guides it down,,,,,,,,if you take the door panel off, is that what is bad or is it the track that actually lifts the glass up,,,,
EvilToywarz
Post by EvilToywarz on Fri Apr 03, 2015 6:53 pm
The metal piece that attaches to the glass with impact tape is still attached..... Yes its the channel that has the 1/4-20 bolt at the top and the bottom of the door, which guides the glass.
That is missing and there is no hardware, someone removed it before me.....I was wondering why the glass kept rocking back when I rolled the glass down.
Do you have an extra one of those parts?
Post by donivan65 on Fri Apr 03, 2015 7:10 pm
I don't have an extra,,,,,,but it just seems like it is just a 24" long piece of 3/4" wide channel like on Screen doors or something,,,,,its nothing special,,,,
Number of posts : 3736
Post by Digz on Fri Apr 03, 2015 7:14 pm
First thing to do is make sure none of your parts are laying in the bottom of the door!
diamond dave
Number of posts : 565
Post by diamond dave on Fri Apr 03, 2015 7:57 pm
I have a couple sets of j bolts that I use with the straps I made. I will dig them out and snap a couple pics tomorrow if I remember. text or call me if you still need one and I can send you pics. 330-612-4338
EvilToywarz
Post by EvilToywarz on Fri Apr 03, 2015 8:54 pm
diamond dave wrote:I have a couple sets of j bolts that I use with the straps I made. I will dig them out and snap a couple pics tomorrow if I remember. text or call me if you still need one and I can send you pics. 330-612-4338
Okay cool...thanx! I will text you tomorrow....
EvilToywarz
Post by EvilToywarz on Fri Apr 03, 2015 8:56 pm
Digz wrote:First thing to do is make sure none of your parts are laying in the bottom of the door!
Yeah I checked that already...8-( On my 1st gen I found the window bracket that mounts to glass, but on my 2nd, no luck!
Post by Digz on Sat Apr 04, 2015 4:15 am
Actually had to replace the part your talking about in my 65 this winter. No easy task as you have to get the window out of the way to access the top screw. Mine was broken off at the bottom bolt and the flat at the top was nearly torn off from getting beat up last fall as I kept putting it off.
Fortunately I had a donor door that was crap as I had to cut the metal out of the door to save that one piece intact. Then finished disassembling it on the bench. Hopefully you can find something out there that hasn't been exposed to this MI weather and come apart easier. If you had the part they can be repaired somewhat.
morbank
Number of posts : 161
Post by morbank on Sat Apr 04, 2015 5:07 pm
I recently made a replacement window channel for my drivers side door (I'm pretty sure there is no difference between drivers and passengers). I don't have a shop so I was stuck making the replacement channel out of a wedge of wood. It took some fine tuning to get the angle just right but once I did it worked pretty good. I used some old ikea hardware for the rails at the top to create the channel for the rubber fuzzy strip to sit in and fastened the wood wedge in place at the bottom with a wood screw. The side of the wood that runs up against where the lock mechanism is has to be notched so that it doesn't interfere with the lock. It looks really stupid but it works and once you put the door back together you can't see it! It's a temporary fix and I ened up getting my hands on a replacement window channel to replace my wood one last week.
    Current date/time is Tue Jan 16, 2018 7:14 am
