    side glass weatherstrip
    Rockandrollerman
    Rockandrollerman
    Number of posts : 24
    Registration date : 2014-05-18
    side glass weatherstrip Empty side glass weatherstrip
    Post by Rockandrollerman Wed Mar 04, 2015 7:43 am
    Anybody know where I can get replacement glass rubber for the side door and drivers pop out glasses for a 66 G10 sportvan? I need the rubber that goes on the body not around the glass.
    Number of posts : 1412
    side glass weatherstrip Empty Re: side glass weatherstrip
    Post by Vantasia Wed Mar 04, 2015 7:50 am
    This kit does around the main window glass and fuzzy strips at the belt line:
    http://www.ebay.com/itm/1964-1970-2-DOOR-CHEVY-VAN-WINDOW-BELTLINE-WEATHERSTRIP-KIT-6-PIECES-/321222813517?pt=Vintage_Car_Truck_Parts_Accessories&hash=item4aca5f274d&vxp=mtr
    If you shop around, it can be found for less.  For the vent windows, Steele Rubber Products makes the rubber for this and several other gaskets for these vans, pricey, but they only make small runs and the cost of tooling a mold is very expensive:
    http://www.steelerubber.com/front-door-vent-weatherstrip-70-2115-55
    Some have said the vent rubber for same year C-10 pickups is the same, but you'd have to verify this. Here is the whole Steel page for G-10 vans:
    http://www.steelerubber.com/search?year=1964&make=chevrolet&model=g10-panel&style=2-door-panel-van
    Post by donivan65 Wed Mar 04, 2015 8:55 am
    I use the sliding door slide out glass gasket off the Dodge mini vans and cut it down to fit,,,,,,
    side glass weatherstrip Repai134
    side glass weatherstrip Repai135
    side glass weatherstrip Repai137
    Rockandrollerman
    Rockandrollerman
    Post by Rockandrollerman Wed Mar 04, 2015 8:30 pm
    Okay thanks. I will look it up.
      Current date/time is Fri Apr 26, 2024 11:20 am
