    Side window seal, help?
    Irwin
    Irwin
    Number of posts : 4
    Registration date : 2014-10-24
    Side window seal, help? Empty Side window seal, help?
    Post by Irwin Mon Feb 09, 2015 9:50 pm
    I'm looking for new window rubber for the side opening windows in the back area of my 1969 A108. I think that this trim will work, but I didn't know if anyone had a source for the right kind.
    I'm thinking in the meantime "fixing" the ones I have with RTV Silicone from Harbor Freight.
    Thanks
    scottie8door
    scottie8door
    Number of posts : 39
    Registration date : 2013-11-15
    Side window seal, help? Empty Re: Side window seal, help?
    Post by scottie8door Thu Feb 12, 2015 5:51 pm
    that looks as if it would work.
    i used jc whitney:
    precion parts weatherstrip seal
    jcw-prpuws13325
    25' @ $45.74 on the website
    3/4" bulb should do 4 windows
    scottie
    Number of posts : 12218
    Post by donivan65 Thu Feb 12, 2015 7:13 pm
    The sliding door glass weatherstrip from the Dodge/Plymouth mini vans works for us,,,,,,like $5 at Pik
    a Part,,,,
    Side window seal, help? Repai124
    Side window seal, help? Repai125
    Post by donivan65 Thu Feb 12, 2015 7:15 pm
    Side window seal, help? Repai126
    Irwin
    Irwin
    Number of posts : 4
    Post by Irwin Thu Feb 12, 2015 8:22 pm
    Thanks, Scotty.
    I put that on order. Looked almost the same as what I had found, but for a little less and your actual usage I think the JC Whitney stuff will work.
    Will post an update when I install it.
    Irwin
    Irwin
    Number of posts : 4
    Post by Irwin Thu Feb 12, 2015 8:26 pm
    I had put in my order before I saw your pick a part post. Thanks for the tip though.
    Number of posts : 956
    Post by slowflapper Fri Feb 13, 2015 8:43 am
    for future reference this worked great on my '65 A
    http://www.mcmaster.com/#catalog/117/3438/=c28rpt
    McMaster Carr part number 1120A131 $1.65 per foot.
    http://www.mcmaster.com/#catalog/121/3498/=vw5kwn
      Current date/time is Fri Mar 29, 2024 12:50 am
