Considering sunroof at some point, and now might be the best time since paint is in the near future after rust repairs.
My body man was looking at the roof area above the cab and was commenting that it appears to be single wall (he can't tell because I have a padded headliner.)
Is that the case?
And, if so, would the sunroof require crossmembers for support? He said that if it needed cross members, now would be the time to do it because adding them later would cause the him to scorch the roof paint when adding supports.
I would just want some type of pop-up or slide that allowed the most air flow and keeps water out. If I had more airflow, I think I could make the brutal summers a lot easier without adding A/C.
No plans for anything fancy. Suggestions wanted.
Is that the case?
