by donivan65 Sat Jan 03, 2015 12:55 pm
I don't have too much faith in finding 50 year old hinges that are not worn out,,,,,,however,,,if that don't work out, I could probably find a hinge for you,,,,,,if the bushing area is worn out, I would just add some weld in it and drill it out to the correct size again,,,,,and is that the section that you need,,,,,,the outer pin section is probably OK,,,,,,,did you use the Chrysler pins and bushings and drill it out with the Letter drill bits?
