66 Steering wheel
Moggy
Number of posts : 17
Registration date : 2014-12-25
66 Steering wheel
Post by Moggy on Wed Dec 31, 2014 12:57 pm
Hi all,
Does anyone have a decent condition original steering wheel for a 66 G10?
Preferably complete with horn ring my horn currently is a button on the dash in a very hard to get to location I've had to let loads of idiots off cos I cant reach it quick enoigh!
Moggy.
Number of posts : 11529
Re: 66 Steering wheel
Post by donivan65 on Wed Dec 31, 2014 1:11 pm
The stock button gets in the way when I am driving and they don't always work correctly,,,,,so I put a button on the front of the shift collar right where your fingers hit if you were pushing on the stock button,,,,,,,
kookykrispy
Number of posts : 1452
Post by kookykrispy on Wed Dec 31, 2014 8:55 pm
I have a good 1st gen steering wheel. I also have a horn button, but it says GMC
Moggy
Post by Moggy on Thu Jan 01, 2015 12:54 am
So the 66 didn't have a d shaped horn ring like a Chevelle or Impala?
If it fits I am not sure I care, how much.
Ray.
kodawolf555@yahoo.com
Number of posts : 1397
Post by Vantasia on Thu Jan 01, 2015 7:56 am
If you are not hung up on a stock wheel, several aftermarket hot rod wheels fit nice with center horn buttons that work. Grant and Mooneyes wheels work. Here is a 15" Mooneyes in metallic blue using the Grant adapter kit for GM in my van, easy install with adapter kit, it has a shallow less than 3" dish, some are deeper and sit too high...still easy to steer with 15", stock is more like 16.5"?
Since this pic was taken , I've painted that radio adapter plate black, looks much better....had to use a plate since a PO hacked up the dash for a huge 60's radio install....easy fix was a plexiglass plate mounted with fancy license plate bolts...
Post by Vantasia on Thu Jan 01, 2015 8:06 am
donivan65 wrote:The stock button gets in the way when I am driving and they don't always work correctly,,,,,so I put a button on the front of the shift collar right where your fingers hit if you were pushing on the stock button,,,,,,,
Doni, Nice idea putting gauges in the ash tray cut out! First time I noticed that in any of your van pics!
Post by donivan65 on Thu Jan 01, 2015 9:22 am
,,,,you really need coolant temp and voltmeter gauges,,,,,right next to a couple of pieces of 4" black PVC pipes mounted on a piece of wood with slots cut in for coffee cups,,,,,,,,
Number of posts : 1293
Post by Lazarusvan on Thu Jan 01, 2015 7:32 pm
On this topic...
Has anyone found a good way to not only repair a crack in the wheel but also keep paint adhered to it?
Stock wheel for me all the way. It's one of the things gives these vans a unique look. One of my favorite things on the van.
    Current date/time is Tue Feb 20, 2018 9:05 pm
